Ive searched, read dozens of threads here and ls1tech, still at square one.
I have the same issue most are having, clutch wont disengage completely, i cant get into gear running.
02 ls1
t56
new ram flywheel
wilwood 7/8 master hinson modified
hinson adapter
stainless braided line
stock slave
centerforce clutch, dont know the model, it came with the trans
Most people say its just the master throw adjustment, but Ive played that game for 3 weeks, and cant make any headway. Ive started all the way at one end, gone half a turn at a time, as far as it goes, to no avail. Ive even removed the adapter to move the throw the extra 1/4 in, doesnt help.
In my reading I stumble on this shimming BS, which I didnt know about when I put the car together, so Im not sure if one should be in there or not. Then it looks like guys are putting on adjustable masters and overcoming these issues without shimming due to being able to move more fluid and push the slave further. So could a 1" master fix it?
Im just getting thoroughly frustrated. Im trying to avoid pulling the trans, but it seems like I might have to pull it, get a new slave, measure and shim if needed, and start again.
On a side note can a t56 be pulled from a fc w/o pulling the engine?
Summer is ticking away, and this is all thats holding me back..
