April 01, 2025, 02:54:35 AM
Author Topic: High Engine temp  (Read 6864 times)
Offline rex388
High Engine temp
« on: April 30, 2012, 10:32:40 PM »
Hey guys, I was just wondering what all you guys have done to enough you don't over heat.  Cause it was only like 20 degrees outside today and even when highway driving (100kmph) my car wouldn't drop below 195.  It stayed around 190-200.  I was thinking of making a bottom fan shroud from my bumper to the rad to help insure that all air moves through my rad and not deflect below it.  I have one on the top already.  But I mean my fan is on all the time and if I can't think of something I will be in trouble come summer.  Thanks in advance.
The only cure for drag racing is poverty
Offline DavidPHumes
Re: High Engine temp
« Reply #1 on: April 30, 2012, 10:33:54 PM »
What do you have for a fan shroud right now? My car ran hella hot last summer because my shroud was insufficient (it was too close to the radiator to be really effective).
195 to 200 really isn't that hot. What do you have for a thermostat?
FC, L33, E85, TC76, 8.8" solid axle, 1.80 PG - Parted Out
NA Miata, FM coilovers, FM sway bars, Hard Dog roll bar, 949 subframe braces - Daily Driver
Offline rex388
« Reply #2 on: April 30, 2012, 10:50:36 PM »
I have a piece of sheet metal that I ran from the bumper to the rad up top.  I have a 165f thermostat.  But I mean I live just above you in Manitoba and it wasn't that hot today.  I am worried about June,July,August.
Offline rex388
« Reply #3 on: April 30, 2012, 10:52:10 PM »
here is a picture.
Offline bikedad
« Reply #4 on: April 30, 2012, 10:54:12 PM »
Where is your temp sender located?
Sometimes block temps can be deceiving. I have mine in the intake manifold but I'm also running a Gen1 SBC.
Don Teifke  :drive:
[smg id=8489]
-----John Wayne-----
Offline bikedad
« Reply #5 on: April 30, 2012, 11:03:03 PM »
My build is very close to what you're running and I'm in Wisconsin.
My temps so far have been no higher than 180. I'm not running a lower shroud but do have a shroud to the top of the radiator.
I run 50/50 coolant with water wetter.
I'm running the Ford Taurus 2 speed fan and it works great.
Don Teifke  :drive:
[smg id=8489]
Offline bikedad
« Reply #6 on: April 30, 2012, 11:09:22 PM »
Oh one other thing, make sure your timing is not retarded.
It could run very rich and extremely hot if you don't have it set correctly.
Don Teifke  :drive:
[smg id=8489]
« Reply #7 on: April 30, 2012, 11:39:15 PM »
help to know what Tstat you are running
Offline rex388
« Reply #8 on: April 30, 2012, 11:41:09 PM »
I have a becool aluminium rad was the same Taurus fan. I have 18 degrees initial, 36 at 3000. Is your rad also on an angle. Mine is tilted forward.
Offline rex388
« Reply #9 on: April 30, 2012, 11:43:08 PM »
O ya and thermostat is plugged in front driverside of the intake.
Offline Speedfab
« Reply #10 on: April 30, 2012, 11:49:25 PM »
Nick's car got to like 260 degrees today... Probably hotter since the sender was only reading steam.  Is that too hot?
Offline bikedad
« Reply #11 on: May 01, 2012, 08:56:20 AM »
My thermostat is a 160 HiFlow with a small weep hole drilled into it.
My water pump is a short aluminum HiFlow.
I'm running a billet 7" overdrive pulley off the balancer. I'll have to measure the billet pulley off the water pump but I know it's smaller than stock.
I looked at your picture and your temp sender is pretty much the same as mine.
Your timing is pretty much the same as mine.
As someone specified earlier 195-200 is really not too hot. But, as long as it maintains that temp and not really any higher than 220 you should be good.
My car will get to 190 on the highway running at 3000 RPM for an extended period of time. But, as soon as I get off the throttle to 2500RPM or off the highway it cools to around 170-180 right away.
Don Teifke  :drive:
[smg id=8489]
Offline rex388
« Reply #12 on: May 01, 2012, 09:00:31 AM »
When I am on the highway I have it in 4th and the lockup on around 2500 only. And it doesn't cool down. Is your rad straight up and down? Cause mine is on a bit of an angle and I am wondering if that has something to do with it. Like when the air hits it to hits it and gets forced under my car instead of through the rad.
Offline bikedad
« Reply #13 on: May 01, 2012, 09:04:52 AM »
Sorry, I forgot to answer that question before.
Yes my radiator sits straight up and down and I have the sides blocked from any airflow around but not the bottom.
My radiator is a Griffin aluminum 27x19 single pass 2" from Summit.
Don Teifke  :drive:
[smg id=8489]
