March 16, 2025, 06:01:06 PM
Author Topic: SOB Racing 87 with a 4G63  (Read 94638 times)
Offline SOB Racing
Re: SOB Racing 87 with a 4G63
« Reply #45 on: December 06, 2012, 02:10:14 PM »
A lot of progress, engine bay stripped, painted and rewired.  Intercooler and exhaust piping completed.   Rad/intercoooler mounting done. Intake manfold and rear sump oil pan fabricated and welded up.
I'll try to post some pictures.
1985 944 Pending a 4g63T Swap
1992 Eagle Talon TSI Retired
12.27 @ 111 on 14B
12.27 @ 113.9 on Small !6g
2006 HHR "The Hearse" Lowered
Offline DavidPHumes
« Reply #46 on: December 06, 2012, 02:14:03 PM »
Love it. This is cool!
Offline SOB Racing
« Reply #47 on: December 06, 2012, 10:09:04 PM »
Ok, here some pictures
Intake manifold all machine out (tablesaw and Router) and ready to tig up.
Tiged by a buddy of mine
Rear sump pan and pickup I made from scratch.  3/8" steel flange and 16g sides
Bottom of the pan serves as the baffle for the pickup
All tiged up by another friend.
12.27 @ 111 on 14B
Offline SOB Racing
« Reply #48 on: December 06, 2012, 10:14:32 PM »
Downpipe from turbo with 40mm waste gate open dump.   If it's too loud, I'lll blend it in to the downpipe downstream later.   bung for narrow and wide band O2 sensors
Smotthed and paint in high temp flat black
Relocated alternator bracket and turnbuckle from scratch.   It's all painted semigloss black
12.27 @ 111 on 14B
Offline SOB Racing
« Reply #49 on: December 06, 2012, 10:27:54 PM »
Here's an older picture with the intake and intercooler piping done.   Can see the radiator/intercooler mounting rack as well.
Overall shot
Tial BOV and GM Maf
Upper radiator line to radiator.   Bare metal C shaped pipe run to the lower radiator fitting
Intake pipe to aircleaner located in factory brake duct
12.27 @ 111 on 14B
Offline Sho Amo
« Reply #50 on: December 07, 2012, 10:02:24 AM »
Nice fab work. This is a great swap.
[Sold] '90 GTU LS1/t56
Offline cool
« Reply #51 on: December 07, 2012, 10:21:10 AM »
Can't wait to see this car on the street.
« Reply #52 on: December 07, 2012, 10:33:31 AM »
Pretty cool.  Nice fab work!
Offline SOB Racing
« Reply #53 on: December 07, 2012, 01:24:50 PM »
Thanks for the compliments.   Since most of this board is LS swaps, I wasn't sure anyone was that interested.
12.27 @ 111 on 14B
Offline DavidPHumes
« Reply #54 on: December 07, 2012, 01:40:54 PM »
I had a 98 GSX with a 2.4 and a FP 3582R. Extremely fun car, great engine - it's just the thing that surrounds it that is less than ideal in many ways. The 4G itself is a fantastic power plant.
This is Modern Automotive Performance's 4G63 FD (they're pretty close to where I live):
http://www.maperformance.com/gallery/pictures/enginebay3.jpg
Now they have a turbo LSX in it but it ran a best ET somewhere in the high 8's with the 4G setup.
Offline SOB Racing
« Reply #55 on: December 07, 2012, 02:38:57 PM »
Yep, seen that beast.   Did a lot of research on 4g63 swaps (really wanted to do a early Chevy II) before deciding on a FC.   i've seen some successful FD swaps but not many completed FC's.   This car won't be what typically run at my local track and that's the aim, to be different.
I love the 4g63 motor, but i"ve been blowing up transmissions for year in my Talon AWD.   The goal is to run low 11's and pull a wheel!  8)  Little different challange than AWD.
12.27 @ 111 on 14B
Offline SOB Racing
« Reply #56 on: December 27, 2012, 10:13:40 AM »
Been working aon a lot of little things.   Brake lines and line lock, wiring up the new Derale relays fand installing 12 " electric fan on the freshly blacked out radiator, and started a pattern for the aluminum radiator shroud.   Also got the 1/2" 2' square slab of aluminum that will become the engine/trans adapter plate, $140 hurt for something that will be mainly chips on the floor.
Big deal was I got the my Talon stripped.   Sucked to take a car apart that I've spent so much time on over the years....but a friend helped the process by selling the trans out of it for me.   Guy needed it in a couple of days so I got right done to it.  So i can now start putting finished parts on the real engine.
12.27 @ 111 on 14B
Offline turbotalon1g
« Reply #57 on: December 27, 2012, 09:26:04 PM »
Nice, can't wait to see how this turns out.
I almost bought a 4G FC a couple of years ago, are you going to get a bigger turbo once its up and running?
Offline SOB Racing
« Reply #58 on: December 27, 2012, 09:34:53 PM »
Yep the engine setup from my Talon (has a small 16g now) will go in with the same tune as a starting point.   As sson as it's running I'll be putting a bigger turbo in, nothing crazy.   Probably a 20g, I like Mitsu turbos.   Easy to work on, as pretty cheep to setup.
Was the 4g FC you were looking at running?
12.27 @ 111 on 14B
Offline uummm
« Reply #59 on: December 28, 2012, 07:10:05 AM »
There was a 4g powered rx7 that a guy in cleveland ohio built a couple years ago, I hit him up on another board getting ideas for mine as thats the route I plan to go.  He sent me a couple pics and vids if anyone is interested in seeing them, I can see if I still have the links and post them up.  AFAIK he used the wideblock 4g, changed the pistons and ran the turbo head and I'm hearing he had twins set up on it for a while.
Now back to the topic, I can't wait to see yours finished op.  I'm interested in seeing what you use for a clutch setup seeing as to how your using a trans adapter.
