March 28, 2025, 07:42:43 PM
Author Topic: COMP Cams Pro-Magnum 1.60 RR replacement PolyLock 7/16" part number help  (Read 3906 times)
Offline mpcv2000
I have a set of 1.60 Roller Rocker from COMP Cams on my stoked LT4 using a 7/16" stud and this weekend a nut came lose making some nasty noises.
I have no damage because I've stopped the car right away.
I've try to re-tork it using the the Shbox write up and even before applying any pressure on the PolyLock it broke right off.
I'll suspect it cracked and came lose but anyway , I've been driving the car for 17,000 KM and this is the first issue I have had with the new motor so far.
Since I'm not too sure of the exact part number of the Roller Rocker and studs I have I ask you guys to give me your inputs.
Here's what I found out when I've removed the valve covers :
It was holding there by 2 or 3 threads.
I was barely starting to tight the Polylock ( 1/8 to 1/4 turn procedure ) and it broke .
I'd like to order 1st thing tomorrow morning what I need to get me back on the road but I'm not too sure if the replacement part I've found is the right one.
I think I need 1401B-1 (..PolyLock search on CompCams web site ..) .
Am I right ?
Thanks.
Martin !
I'd call Comp, they might just send you a new one.
Offline mpcv2000
I will give them a call tomorrow.
Someone on LS1Tech found the part number I'm looking for .
Part number needed 4603-16 .
Rocker Arm Nuts, Magnum, Roller Rockers, 7/16 in.-20 Thread, .6752 in. Outside Diameter, Set of 16
Martin !
Offline mpcv2000
Thursday evening .
I'm getting ready to re-assemble my top end ( if I can say ) and I've ordered the wrong PolyLocks .
Maybe I have a older sets of 1.6 Roller Rockers and the PolyLock are different ?
Anyway here's what I've got :
Right is the new one ( obvious )  ;)
Now left is the new one.... :secret:
I was hoping my car will be running tonight but looks like it won't happen.
I have also someone at CompCams that is aware of what I'm looking for so I hope I'll get the right part number before noon tomorrow so I can get the part on Friday.
 :drive:
Martin !
Offline mpcv2000
With what I know now I went back on COMPcams web site and found the right one I think :
Rocker Arm Style                      : Full roller
Rocker Arm Nut Style              : Polylock
Rocker Stud Thread Diameter           : 7/16-20 in.
Overall Height (in)                      : 1.000 in.
Outside Diameter (in)              : 0.600 in.
For Use with Stud Girdle                   :No
This time I've mesured the nut and they matches what's above.
I should have done that yesterday......:(
Martin !
Offline bikedad
Wow. Good thing it broke while you were tightening it.
I had a rocker stud snap at 7000 RPM and caused "Bikedad Go Boom" thread.
My engine having solid lifters has me adjusting them every 2000 miles or so. I don't mind it though. I like tinkering around in the engine and this way I find the weak points before they happen. (Hopefully  ;))
Don Teifke  :drive:
[smg id=8489]
-----John Wayne-----
Offline mpcv2000
It broke at the track ( around 6,000RPM ) my guess  .
I traillered the car back home.
I realized it was broken when I've tried to torque it.
1st I thought it just got lose somehow.
My guess is I have no motor damage but I haven't started the car since it is still not fixed.
Martin !
Offline bikedad
You're probably fine with your motor.
When my rocker stud snapped the car backfired and blew the intake manifold gasket out at the water jacket. I was just coming into the traps when it happened.
It flooded cylinder 3 and hydro-locked it. Lot's of smoke and noise when it went.
That's when I decided to go the stroker route.
Comp Cams sent me new improved rocker studs. That's what I have now.
Don Teifke  :drive:
[smg id=8489]
Offline mpcv2000
Got the kit today 4600-16 .
They are not the right one again.
I need to have the machined end to fit the 1.6 Roller Rocker grove.
Like you can see the old one fits into the grove perfectly .
The new one are a too big .
I said fuk it I'm not going to wait another week so I grinded it down....
Now it fits perfectly. ( not nice but....)
Back together.
I've started the motor and it runs perfectly , like before.
I'm very happy I haven't broke anything.
Martin !
