March 18, 2025, 04:14:42 AM
Author Topic: Coming Over To The Dark Side....  (Read 21493 times)
Offline mefarri
Re: Coming Over To The Dark Side....
« Reply #60 on: August 29, 2012, 09:40:43 PM »
Looking forward to seein what the new #'s are going to be.
-Jimlab
-Blake motherfucking McBride
« Reply #61 on: September 05, 2012, 03:43:12 AM »
Hope you are fairing well with the hurricane.  Give us an update when you can.
Offline Scottie-GNZ
« Reply #62 on: September 05, 2012, 08:24:32 AM »
We got spared....again. Redoing the rear suspension alignment with hopes of making it out for a few light hits on Friday.
Scottie
8.71 @ 156.79
Offline Scottie-GNZ
« Reply #63 on: September 07, 2012, 10:59:04 PM »
Broke out the GoPro I bought several months ago and did a walkaround with the engine idling in the driveway. Bit of a crap video as I used the default GoPro mode 4 which gives sort of a bird's eye view and for some reason, the audio is barely audible, so you need to crank up the volume just to hear it idle.
Scottie
8.71 @ 156.79
Offline screamin88
« Reply #64 on: September 08, 2012, 10:22:38 AM »
I love this car.. awesome work!
« Reply #65 on: September 09, 2012, 01:37:08 AM »
that thing is bad ass Scottie!  Nice setup.
Now change your signature ;)
« Reply #66 on: September 30, 2012, 03:06:08 PM »
I assumed you are all good Scottie after the hurricane and suffered no real damage/issues to your property/vehicles?  Any updates?
Offline Scottie-GNZ
« Reply #67 on: October 01, 2012, 12:32:38 AM »
Hurricane did not affect my area, but been waiting 4 weeks to get the car out because of rainouts and vacation. Took the car out Friday night but quit after 2 hits. Need to make suspension adjustments - pulling to the left and blowing off the tires on the launch. More concerned about electrical glitches though. Burned up the alternator last week and barely made it home with the voltage down to 8.9v. No idea how the engine kept running. Replaced the alternator, but Friday night, the battery voltage was erratic and dropped down to 12.1v during a pass. Datalog showed several Loss Syncs and it was running lean with the pump getting such low voltage. Now suspect the problem is the Optima Red Top and going to replace it since I cannot even remember how long ago I bought it. I am sure it is more than 3 yrs old, maybe 4. Would not be surprised if the Optima caused the alternator failure.
I am amazed at how quick I can spool this turbo. It is a T6 S480 with a 97mm turbine wheel and 1.32 a/r housing and it is spooling too fast. Gonna have to play with pulling timing and richening up the fuel during spoolup and maybe replacing the ATF with heavy weight JD Hyguard.
Wanted to shake out the bugs and I got them  ::)
Oh yeah, Zak was there with his turbo FD. Man, what a gorgeous car!
Scottie
8.71 @ 156.79
Offline Tictakman
« Reply #68 on: October 04, 2012, 11:06:03 AM »
Scotty, it was great to meet ya finally!  Once you get the few bugs worked out in your car its gonna be a runner...  Did you find out about the voltage issue?  Call the alternator place too?
Zak
Offline Scottie-GNZ
« Reply #69 on: October 05, 2012, 04:47:53 PM »
Hey Zak,
car has been sitting outside in the rain since Saturday  :( and only thing I was able to do was replace the battery, remove the front-end limiters and order some softer rear springs. I did send a datalog in for analysis and it was recommended I reinstall the firmware since there appears to be possible corruption. Got caught up in some projects that I had committed to get done.
Scottie
8.71 @ 156.79
Offline Sabre002
« Reply #70 on: October 05, 2012, 05:05:50 PM »
What factory manifolds did you end up with?  I remember some being better to weld on for some reason?
Josh
Jsmit295@mazdausa.com
Offline Scottie-GNZ
« Reply #71 on: October 06, 2012, 12:36:37 AM »
If you mean the Mustang, I am using truck manifolds, flipped with v-bands. Nothing special to weld.
Scottie
8.71 @ 156.79
Offline Powerlover
« Reply #72 on: October 25, 2012, 05:26:31 PM »
Good to see you still showing the kids how to do things the right way!  Been a long time since we met in Reynolds.  You still see Mike around?
Offline Scottie-GNZ
« Reply #73 on: October 25, 2012, 10:37:28 PM »
A blast from the past! How you been?
Still see Mike, but he is married with a couple of kids and got rid of all the cars.
Scottie
8.71 @ 156.79
Offline Powerlover
« Reply #74 on: October 26, 2012, 09:07:43 AM »
Been good! Tell Mike I said hi! I sure wish I had time to build another project. I miss the community.
