March 18, 2025, 02:47:40 AM
Author Topic: Coming Over To The Dark Side....  (Read 21490 times)
Offline Scottie-GNZ
Re: Coming Over To The Dark Side....
« Reply #45 on: August 18, 2012, 03:17:49 PM »
Got my itchy finger on the start button......but not quite yet. Driveshaft was a .5" too long so had to take it back, need to spend a little time in the back room at Autozone to "rig" up coolant hoses, need to finish the dipstick mod (PITA), some minor wiring and fill up the liquids.
Not keen on cranking the engine dry hoping I get oil pressure quickly, so I am going to try a little drill-driven pump from HF and try to put all the oil in with some pressure.
Scottie
8.71 @ 156.79
« Reply #46 on: August 18, 2012, 03:25:39 PM »
looks real good!
where those 2618 or 4032 pistons?
Offline forcefed86
« Reply #47 on: August 18, 2012, 06:12:15 PM »
Looks good! What water pump pulley is that?
Offline Scottie-GNZ
« Reply #48 on: August 19, 2012, 12:15:24 AM »
4032.
Supposed to be LS1 WP. Something look different about it?
Scottie
8.71 @ 156.79
« Reply #49 on: August 19, 2012, 12:19:25 AM »
Looks the same as my '98 LS1 water pump off an F-body.
Offline forcefed86
« Reply #50 on: August 19, 2012, 12:30:41 PM »
Thats odd, my 98 F-body LS1 had this pump. It doesn't have the bolts on it like the one in scotties pics, it's just pressed on. The snout looks like it sticks out farther as well.
The pump in this thread looks like it would give me some additional room up front. All the aftermarket units look like the unit I have. I'd like to try out the one with the bolts on it like you have.
I found a few similar to yours on google pics. But all the vendor sites and ebay don't seem to carry the water pump with the bolts.
« Last Edit: August 19, 2012, 12:42:42 PM by forcefed86 »
« Reply #51 on: August 19, 2012, 01:02:17 PM »
I don't think the overall length is any different, FWIW.    I've owned about all the different water pumps they make for LS motors over the years.   The LS2 ones are the tightest in, but you have to pull the pulley out a bit for F-Body accessory offset.
Offline DavidPHumes
« Reply #52 on: August 19, 2012, 02:16:43 PM »
Great job Scottie. Very clean, nicely laid out and we all know it will haul the mail. I'm excited to see it run.
« Reply #53 on: August 19, 2012, 08:52:33 PM »
looks good so far!
What size injectors did you go with?  e85?
Offline Scottie-GNZ
« Reply #54 on: August 20, 2012, 08:41:02 AM »
Injectors are Bosch 160# hi-impedance.
Scottie
8.71 @ 156.79
« Reply #55 on: August 20, 2012, 04:41:02 PM »
nice.... you need to change your signature Scottie.....   :chug:
Offline ALLslowNOshow
« Reply #56 on: August 22, 2012, 08:30:48 AM »
I think they were usually found on early C5 vettes.
Randomly I did find one on Ebay, figure I post it up if you were interested:
http://www.ebay.com/itm/2001-Camaro-Water-Pump-Ls1-/221108393828?pt=Motors_Car_Truck_Parts_Accessories&hash=item337b165764&vxp=mtr
86 GXL - LQ9/T56
Offline Scottie-GNZ
« Reply #57 on: August 25, 2012, 04:52:26 PM »
Up and running, but not without some, ahem........challenges.
MAP sensor readout was way off, 69.3kPa with key-on/engine-off, coolant sensor was 35*F high and engine would get very hot quickly from a t-stat stucked closed. Kinda pointless trying to start and tune the engine with those sensors being off and took a while to discovered that the ECM was built with a 4-bar instead of the standard 2.5-bar and I had the scaling set for a 2.5-bar. MAP sensor is inside the box so I did not see it. Fixing the MAP setting also corrected the coolant sensor readout. Surprised to find I could get a 160*F t-stat/housing from Autozone but have not installed it yet. Duralast part #37960 if anyone is interested.
Put the car aside to work on my generator which has been sitting for 3-yrs :-[  Spent most of the day chasing down a carb rebuild kit. Want to be ready in case Isaac makes a right.
Scottie
8.71 @ 156.79
« Reply #58 on: August 25, 2012, 05:32:35 PM »
Glad to hear it's coming along.  :)
Offline Scottie-GNZ
« Reply #59 on: August 29, 2012, 09:32:18 PM »
1 step forward, 1 step back.
Took the car for it's maiden voyage yesterday after days of on/off rain. 1st impression was that the V8 was not as smooth as the inline-6, but soon as I started to put some power down, I knew I had a driveline vibration. Nothing was changed in the rear but when I checked, the pinion was 3.5+* up instead of 2.5* down! Had to call it quits yesterday and today is my anniversary so I stayed out of the garage to make wifey happy. Suspect something might be bent/broken
Scottie
8.71 @ 156.79
