March 18, 2025, 04:14:42 AM
Author Topic: Coming Over To The Dark Side....  (Read 21492 times)
Re: Coming Over To The Dark Side....
« Reply #30 on: June 08, 2012, 09:02:56 AM »
They are "C6 LS2 exhaust manifolds" if you look for them.    They sell for about 100-125 dollars a pair, shipped, over on CorvetteForums, and when I put up a WTB over there I got like 10 offers in 3 days.    Easy to get at.
I have two cars in my garage with turbo kits VERY similar to the one Zac has.   They work really well.
Offline Scottie-GNZ
« Reply #31 on: June 08, 2012, 04:21:22 PM »
Thank you, Sir.
Scottie
8.71 @ 156.79
Offline Scottie-GNZ
« Reply #32 on: June 13, 2012, 05:52:22 PM »
Aaaargh!!!!! I really F'ed up big time with these manifolds and kicking myself in the ass!
Found and bought a pair of LS2 manifolds and stupid me sold the modded truck manifolds even before I got LS2s and now they don't fit. Neither side! The outlet on both sides are too close to motor mount brackets and since the manifold is thicker, it interferes with the steering flex joint. Exactly what I thought would happen in the first place. Luckily I have another pair of truck manifolds, so here we go again.
Anyone need a pair of LS2 manifolds?
Scottie
8.71 @ 156.79
« Reply #33 on: June 13, 2012, 10:57:19 PM »
Welllllll shit.   Sorry man.   They fit great on FCs.   :(
Offline forcefed86
« Reply #34 on: June 14, 2012, 12:53:13 PM »
Have you looked into the ls3 manifolds? They seem to be the new hot ticket around here. I ended up with 6 sets of LS manifolds. None of them fit.  ::)
Offline andrewb70
« Reply #35 on: June 16, 2012, 03:55:36 PM »
Good to see you back at it Scottie! Hope all is well with you.
Andrew
Dr. EFI
Remote Holley EFI tuning
IG: Projectgattago
FB: Projectgattago
Offline Scottie-GNZ
« Reply #36 on: June 26, 2012, 09:07:18 PM »
Hey Andrew. How you been?
Update: Hot and cold side plumbing all done and engine pulled and dropped off at the machine shop for rods/pistons/ARP hardware.
Scottie
8.71 @ 156.79
« Reply #37 on: June 26, 2012, 10:14:25 PM »
lookin good!
What size wastegate and diameter crossover piping?
Offline Scottie-GNZ
« Reply #38 on: June 26, 2012, 11:14:37 PM »
X-over pipes are 2.5" and WG is a JGS 50mm. The WG pipe comes off the merge collector at 45* then has a slight bend to take it away from the turbine housing. When I get the DP and exhaust done next week, I will mount up the turbo, piping and WG so the setup will be a little clearer.
Scottie
8.71 @ 156.79
« Reply #39 on: June 27, 2012, 12:10:50 AM »
Nice work Scottie!
Offline Scottie-GNZ
« Reply #40 on: August 07, 2012, 04:24:31 PM »
Decided to do a bullhorn. Whaddayathink?   :poke:
Scottie
8.71 @ 156.79
« Reply #41 on: August 07, 2012, 04:57:18 PM »
moar!
Offline Scottie-GNZ
« Reply #42 on: August 07, 2012, 10:12:57 PM »
Everything else is done but hit a snag with the engine assembly that caused a delay. Buddy could not find his piston ring filer so we rigged up an alternative but underestimated how aggressive it would file. Oops! Screwed up the 1st ring. Rest came out fine but had to special order a single-cylinder set to avoid buying a complete set. Should have it done in a couple of days.
9.5:1 Mahle, Eagle rods, ARP main studs.
DP and exhaust. All 4" aluminum with a magnaflow.
WG Dump
Scottie
8.71 @ 156.79
« Reply #43 on: August 07, 2012, 10:20:50 PM »
Looks good Scottie.   :)
Offline Rayminator
« Reply #44 on: August 07, 2012, 10:22:18 PM »
Looking good Scottie, aim that exhaust slightly to the rear, for a little added "thrust".
I hope to see this set-up in action, when I come down this fall.
