Quote from: 65imp on March 29, 2012, 12:40:36 PMWith that much effort I think you are kinda obligated to do a really trick/clean wire tuck. Relocating the coils, re-loomed harness, etc. I am sure your VW buddies have some tricks up their sleeves in that department as well. Great work so far, I imagine ou spent several nights questioning your sanity as you sat in your engine bay... One question: Did you consider filling in the front fender openings with metal? I have seen a couple guys do that, and it is a cool effect in a really smooth bay.I plan on wire tucking the bay as much as possible. The Injector clips and coil harnesses will be seen. i considered relocating the coils, but honestly, i think it will look better with them ontop cleaned up. The car is not strictly a show car, it will be worked on at some point, so things need to be accessable. i did consider filling the front fender openings, but thats a lot of metal and i didnt feel it necessary to do them. I questioned my sanity every day for the past 4 months lol-Austin
Car looks amazing.. Where are you in Baltimore? I almost never see any 7's running around.
Quote from: skeltah on March 30, 2012, 11:17:03 AMCar looks amazing.. Where are you in Baltimore? I almost never see any 7's running around.Thanks, Im a little bit north of Baltimore in the Bel Air area.-Austin
i'm pretty sure i've seen you at the wawa in hickory. i live on harford rd.
No...and even if i did, i wouldnt give it to u lol ;-)In person, it slightly resembles the color used on vipers.-Austin
