March 18, 2025, 05:42:44 AM
Author Topic: Problem with RR Caliper... does not "slide"  (Read 1861 times)
Offline mattster03
« on: March 22, 2012, 10:29:16 AM »
Has anyone run into this before?  I am just about done with my brake and suspension upgrades and I'm trying to re-install my right rear caliper that I have painted & replaced the pads on.  It's difficult to describe the problem b/c I don't know the proper word for the part, but the "floating" half of the caliper that slides in and out freely is not sliding in and out freely.  Any advice?
Re: Problem with RR Caliper... does not "slide"
« Reply #1 on: March 22, 2012, 10:29:52 AM »
Pull the pins, clean them and grease them.  :)
Offline Demon
« Reply #2 on: March 22, 2012, 10:30:18 AM »
Get new sliders and bolts from a parts store, should be like $20
Offline mattster03
« Reply #3 on: March 22, 2012, 10:35:56 AM »
Cool, is this a Mazda Specific Part that I would have to order from the dealership?  Surprsingly I really haven't worked with brakes too much so I'm quite a newb at dealing with them.
Offline mr3plus1
« Reply #4 on: March 22, 2012, 01:03:58 PM »
Honestly Ive always been able to just clean the pins with a wire brush and re-grease them to get them unstuck.  Dont see the point in buying new ones unless the old ones are damaged in some way.
Offline gc3
« Reply #5 on: March 22, 2012, 01:05:56 PM »
sometimes they get so bad with rust that they are no longer the right diameter in areas.
Offline Demon
« Reply #6 on: March 22, 2012, 01:35:03 PM »
Any parts store will have it.
Offline mattster03
« Reply #7 on: March 23, 2012, 10:45:17 AM »
I got it all taken apart cleaned and lubed up last night with some grease.  It was a PITA to pull the pins out but I got them out finally.  I will definitely be rebuilding the calipers over the winter  :o
Offline Donthitme
« Reply #8 on: March 23, 2012, 04:02:22 PM »
I found it easier to get remanufactured for $40 a pop+core.  If you do get reman ones remove the parking cable brackets, some of them dont come with it.
