March 16, 2025, 01:26:08 AM
Author Topic: Rawr! 1992 RHD FD 5.3 Turbo build  (Read 45303 times)
Offline karsty
Re: Rawr! 1992 RHD FD 5.3 Turbo build
« Reply #30 on: June 19, 2012, 10:54:29 AM »
Drool!
« Reply #31 on: June 19, 2012, 12:13:26 PM »
SFI bellhousing, eh?
*Tries to step my game up*
*Trips over something instead*
Offline RawrX8
« Reply #32 on: June 19, 2012, 01:31:04 PM »
 :yay:
Want to lessen the risk of a flywheel coming through the floor.
Something else is a wilwood pedal box to address the rhd master cyl issue.
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
« Reply #33 on: June 19, 2012, 01:38:37 PM »
Smart. But what I find most inspiring is your neatness and organization, it sets a good example.
« Last Edit: June 19, 2012, 07:20:00 PM by spacevomit »
Offline BrownBoy
« Reply #34 on: June 19, 2012, 07:18:10 PM »
Oooooh that's hot! :)
Offline RawrX8
« Reply #35 on: June 21, 2012, 01:18:13 AM »
Well bummed right now because I had Justin make me some engine mounts. They are lost in the mail :( USPS said they were delievered on the 6th but nothing has came for me. So today I was in the garage simple green scrubbing the interior of the car. I didnt make it that far because I changed a pandora station and looked at my pile of control arms.
Wishing I could superman push the bushings out with my finger; Friday im going back up to the shop. I didnt like the exterior of the arms. Flipped on the flap wheel and started to eliminate a stress riser. Chances of a stress crack happening is like winning the lotto, but its common practice daily for me at work. It was better then scrubbing with simple green.
Anyways, no ones ever going to know I did this. Its just a little free mod for myself  :yay:
Hopefully Ill get a chance to bead blast everything while im pressing my last few bushings out. I know I wanted to powdercoat everything. Im just going to spray paint them. They are going to get beat on by rocks and god knows what else. Dont want to cry when I notice chipped coating.
Still a lot of work to do but I am working 12hrs a day so I can keep the funds up to finish. Im sure things will start speeding up when the motor is sitting in the car  :yay:
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
« Reply #36 on: June 21, 2012, 02:51:04 PM »
I'm assuming you realize that powdercoat can stand up to a hell of a lot more abuse than spray paint? It would provide a small amount of protection to the arms themselves. IMO it has a functional justification.
Offline RawrX8
« Reply #37 on: June 21, 2012, 03:37:37 PM »
Youre prob right and its still an option. Need to find the ripped ball joint boots to slip back over so they wouldnt coat over the b-j.
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
Offline karsty
« Reply #38 on: June 21, 2012, 03:40:11 PM »
I say polish up that aluminum and leave that as the finished product.
« Reply #39 on: June 21, 2012, 04:12:41 PM »
You could use one of the textured powders like silver vein. Optionally you could then put another color over that.
Offline RawrX8
« Reply #40 on: June 25, 2012, 01:51:09 AM »
After I went for a nice trip in a B17 I came back and bought some dry ice. Im leaving the firewall because it will be covered up by the dash. There are a few spots I need to go back and apply heat since freezing them even for 30 mins didnt do anything. Wire wheel rest and acetone. Seam sealer is next to remove.
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
Offline RawrX8
« Reply #41 on: June 28, 2012, 01:17:18 AM »
So today I got around to finishing something I started a long time ago! I dont have time to visit the shop our press is being kept at so I had to use something else. It worked and gave me a work out. Anyways heres the pictures. Friday maybe ill get off early and go bead blast everything and fresh paint this weekend/install bushings!!!
My poor pands press.
This was the last one to get out. Sadly I did have a socket that fit inside just right. Cut a small piece out and knocked it out with a punch.
How I felt after...
Now it was time for a cold one....forever alone...
BTW since the 4th of July is coming up. Right at the padding of my thumb you can make out a scar. I almost lost my thumb last year to an explosive. Careful! Matt actually saw me when I sold him my wheels and I was still in a cast.
Everything all pressed out :yay:
All the dead bushings/pillow balls
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
Offline RawrX8
« Reply #42 on: June 29, 2012, 10:12:19 PM »
Cleaning up a control arm to test out paint I had UPS bring me a nice package!
DSS Pro Axle 8.8 Kit
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
Offline RawrX8
« Reply #43 on: June 29, 2012, 10:43:30 PM »
Gave this a try on one control arm. Looks cool. Needs some clear enamel and will be great.
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
« Reply #44 on: June 30, 2012, 01:19:57 PM »
What do you call that special grip in the last one? Teach us that.
