#30 by digitalsolo on 22 May, 2010 10:59
#31 by Andrew R on 22 May, 2010 20:12
#32 by bikedad on 22 May, 2010 20:45
I had the same fan you have on my old radiator. It worked sort of OK with easy driving. When the temp would creep up with harder driving that fan couldn't keep up. I would end up shutting down the engine and let it cool with the fan on.
My junkyard 95 Taurus 2 speed fan has no problem now. Works like a charm and no concerns any longer. I even got stuck in a traffic jam and it maintained 195 degrees. (That's what the high speed temp sensor is set at) They really suck! (air)
I paid $45 for the Taurus fan from the used auto parts reseller (junk yard you can't go into). If you have access to a "pick apart" yard you could probably get it for $20. -
#33 by Andrew R on 23 May, 2010 06:41
I have me eye on a 4,000 cfm fan that I'm going to get if this one is not up to the task... I pretty much have enough room to run anything I want. -
#34 by HTh3r0 on 23 May, 2010 07:30
guess i'm sticking with my taurus fan in the town and country shroud. . TheMike finney get up. I was gonna get a spal HO. Their site it say it doesn't last as long as their other fans because the motor isn't sealed and is exposed to the elements
#35 by Andrew R on 23 May, 2010 15:54
#36 by Pez on 23 May, 2010 17:19
Why do you have 3 fan relays?
#37 by Andrew R on 23 May, 2010 18:37
Just in case I add more fans later -If I have cooling issues I'm going to switch to a dual fan set-up.
#38 by Andrew R on 29 May, 2010 22:06
Buttoned up the cooling today -trans fluid is in, intake is semi-complete (enough to start it) Fuel system is all set, suspension is torqued down, DS installed. I might actually drive this thing soon. Just started the final install if the wiring.
Saw this at the track sat:
LS7 350z -G-force 5 speed -one of the cleanest builds I have ever seen. He put 523 to the rear wheels. It has a ARE dry sump system that made me cream my pants.
#39 by digitalsolo on 29 May, 2010 23:40
Car is looking good. That 350Z is beautiful!
#40 by Speedfab on 30 May, 2010 12:24
#41 by digitalsolo on 30 May, 2010 12:25
Tracy is crazy. You'll also need duct tape.
#42 by Andrew R on 30 May, 2010 12:41
#43 by Andrew R on 31 May, 2010 17:17
Here is a shot of the rear as of now... I'm building a new body harness from scratch -everything is shrink wrapped and awesome -used some wirecare wire sheath -came out looking really clean.
brake lights, running lights, and hazards are wired up as well as fuel pump. Moved the location of my main board and secured the battery. Still not done and will be cleaning up a little more and sheathing more wire, I'm also going to make a cover for the main board. The interior will go back in...
#44 by slwrthnu on 31 May, 2010 17:59
i had no clue that 350z was ls7 powered, damn that makes me like it more.
