March 31, 2025, 08:45:38 PM
Author Topic: Andrew R LS2 T-101 dogbox FC  (Read 89672 times)
Offline Andrew R
  • Superunnatural
Re: Andrew R LS2 T-101 dogbox FC
« Reply #15 on: May 06, 2010, 04:32:16 PM »
here is a how to list:
www.delcity.net
Qty        Item                                               Price       Item Total
100        152105    Ring Terminal, 10 Stud, 16-14 Ga (100 MIN$0.02780
100        152145    Ring Terminal, 1/4&#34 Stud, 16-14 Ga (10$0.04390
100        152565    Ring Terminal, 5/16&#34 Stud, 16-14 Ga (1$0.04390    $
100        192005    Female Push-on Terminal, .250&#34, 16-14 $0.03640
200        221005    Butt Connector, 22-18 Ga (100 MIN)       $0.04620
200        222005    Butt Connector, 16-14 Ga (100 MIN)       $0.04620    $
500        3714505   Black Cross-Link Wire, 14 Ga (500 ft. MIN$0.12750
500        3718505   Black Cross-Link Wire, 18 Ga (500 ft. MIN$0.06990
25         5210205   Black Battery Cable Coil, 1/0 (25 ft. MIN$2.56670
5          70004     10 Stud Terminal Block (1 MIN)           $6.00
8          73020     SPST On-Off Toggle Switch (1 MIN)        $2.11
1          73495     (ON)-OFF Moisture-proof Push-button Start$6.22       $
12         73572     Socket with &#34ISO&#34 Relay, (1 MIN)   $4.26       $
4          73820     ATC™/ATO™ 6-way Fuse Block, ($5.50
2          73920     Two-pin Thermal Flasher, 12V (1 MIN)     $1.58
2          80500     6-way, Buss Bar w/Cover, 100A DC (1 MIN) $22
5          906545    1/4&#34 Copper Lug, 1/0 Ga (1 MIN)       $0.4
10         906645    5/16&#34 Copper Lug, 1/0 Ga (1 MIN)      $0.4
10         907445    3/8&#34 Heavy-Duty Copper Lug, 1/0 Ga (1 $1
1000       9623      Cable Ties, UV Black, 4&#34 (1000 MIN)   $0.01186
1000       9627      Cable Ties, UV Black, 6&#34 (1000 MIN)   $0.01698
2          98061505  4 ft. Black Dual Wall Shrink Tubing, 1/8&$2.11
1          98062505  4 ft. Black Dual Wall Shrink Tubing, 1/4&$2.58
1          98063505  4 ft. Black Dual Wall Shrink Tubing, 1/2&$3.58       $
1          98064505  4 ft. Black Dual Wall Shrink Tubing, 3/4&$5.22
« Last Edit: May 06, 2010, 04:46:56 PM by Andrew R »
Offline Andrew R
  • Superunnatural
« Reply #16 on: May 17, 2010, 06:30:04 AM »
^^^   I built my version of that over the weekend -came out pretty sweet -mine is going to mount on the firewall by the passengers feet -New rotors and pads all around, brakes and slave are bled. Ran outta welding gas Sat morning and there was no where open to get more so I did a bunch of small things to help me get a head start on the wiring. Tonight I'll be finishing the trans mount -I made mine so the exhaust goes UNDER it -I'll put up some pics tonight.
I'm trying to make an event in two weeks...  this week will be detrimental -I NEED to have it running next weekend so I can shake it down a bit and hit the dyno...  major projects left -wiring, exhaust and cooling -I pretty much have everything planned out -just a race against time and I'm not rushing anything -I'm expecting some sleep deprivation this week -I might even take a day or two off work.
Offline Andrew R
  • Superunnatural
« Reply #17 on: May 18, 2010, 06:39:59 AM »
So I fabbed up this little guy today -originally I was going to do a straight bar across kinda like Hinson, Grannies ect...  just seemed that the exhaust would be such a PITA that I would rather spend the time on the mount and run a practically straight exhaust.  I used some 1/4" thick flat stock and angle with some hefty rectangle bar I had laying around. The mount bolts though the trans tunnel and I made "sandwich plates" out of 10 gauge mild steel on the interior. I still need to weld in the plates -but everything is set.
Offline Andrew R
  • Superunnatural
« Reply #18 on: May 19, 2010, 11:07:40 PM »
Super progress the past few days...
Trans is in place -moved on to the rad and intake tonight:
This hole support is a bolt in affair now -six bolts and the rad and support come out together.
Started eyeballing the intake:
Offline ProjectD
« Reply #19 on: May 20, 2010, 12:08:39 AM »
Build is looking great, but I just don't see the radiator being very effective in it's current position. It doesn't even look like ducting will help. Maybe I'm missing something, have others had success mounting the rad in that position?
Offline Andrew R
  • Superunnatural
« Reply #20 on: May 20, 2010, 06:13:32 AM »
I have seen this rad set-up done plenty of times on other cars usually turbo cars in a "V mount" I'm just going to use ducting for the top -not an intercoooler -honestly I'm kinda regretting doing this set up at the moment because it is going to take another few days to button it up and I'm prob going to miss next weekends event.
Offline ProjectD
« Reply #21 on: May 20, 2010, 10:37:31 PM »
That's what had me confused,  It looks like an incomplete v-mount with nothing to force air down through the radiator. And the intake/filter is sitting right where your duct would be.
Offline Andrew R
  • Superunnatural
« Reply #22 on: May 20, 2010, 11:09:31 PM »
Yeah it is no where near done -I did paint everything and get it ready for install...  shrouding/ducts in the near future.
« Reply #23 on: May 20, 2010, 11:14:41 PM »
I cannot wait to hear you bang gears in this thing  :)
Finish it up already!
(you will have in car video won't you?)
Offline Andrew R
  • Superunnatural
« Reply #24 on: May 21, 2010, 07:17:22 AM »
Gopro HD is on my wishlist.
Offline Andrew R
  • Superunnatural
« Reply #25 on: May 21, 2010, 04:38:43 PM »
Just picked up my driveshaft   :)
Offline andrewb70
« Reply #26 on: May 21, 2010, 06:41:19 PM »
I am a little worried about cooling issues, but time will tell.
Andrew
Dr. EFI
Remote Holley EFI tuning
IG: Projectgattago
FB: Projectgattago
Offline Andrew R
  • Superunnatural
« Reply #27 on: May 21, 2010, 08:44:48 PM »
^^^  Cooling will be fine...  I have a few tricks up my sleeve.
DS fits like a glove!  8)
did a test fit of the dash  - I need to get a different shifter lever:
« Last Edit: May 22, 2010, 07:50:51 AM by Andrew R »
« Reply #28 on: May 21, 2010, 10:29:17 PM »
LOL, semi-truck shifters for the win man!    ;)
You crazy drifters and your weird ass radiators...
Out of curiosity, why did you do it that way?   A "normal" setup would fit just fine...   :)
Offline Andrew R
  • Superunnatural
« Reply #29 on: May 22, 2010, 06:38:34 AM »
seemed like a good idea at the time... -wanted the intake to go over it.  If I have cooling issues I have no problem hacking up the front bumper.
« Last Edit: May 22, 2010, 07:35:59 AM by Andrew R »
