OK here goes...
you all know the modified knuckle -with the stock rod end pick up... look a few posts above if you don't.
Here is the modified knuckle:
Now you'll notice right off that the ID of the new pick up point is different... larger and not tapered like the factory pick-up.
This posed the issue of finding a heim joint that would work, by work I mean thread on to the factory tie rods and have a 14mm ID for the new pick-up point. I know the mazdatrix ones would work... but they are procey and suck donkey dick... I threw out the question on a few sites and George from AZ informed me that the S13 rod ends were the same thread pitch as the FC, M12x1.25 and that a Ksport S13 kit might just work. Now K-Sport S13 kits come with a tapered bolt in them as well that is easily removed leaving a 14mm ID heim joint thats mated up to a M12x 1.25 buckle... perfect! I now have proper parts! I know K-sport sucks -but I'd rather spend $100 for a set and figure out exactly what I need then get something baller once I know it's going to work.
here is the new rod end and straight bolt
NOW I KNOW THIS IS NOT A CASTLE BOLT ECT -TEST FIT HERE!!! SO DON'T SAY ANYTHING! I KNOW ALREADY! proper bolts are on the way.
here is the K-sport rod end with new non-taper bolt:
[SIZE="3"]
(again this will be replaced with a castle bolt)[/SIZE]
Stock vs. K-sport.
time to fit it:
as expected fits right on:
Now it is simply a matter of attaching the tie rod to the spindle! almost done!!! or am I?
here is the two put together:
Mega angle! -but wait... no adjustment!
if you look back at the pic above of the rod end and the tie rod put together you'll notice that I have it run in as close as I could get it, or as short as I could make the tie rod...
that was still too long, when I assembled everything back together with the Steering wheel centered and the tie rods adjusted as short as possible I was toed out on both sides really bad, could not drive the car bad!
If you look at these pic closely you can clearly see the toe out:
AGGGGHHH!!! :mysmilie_174:
OK... I need to shorten the tie rod... -but not too too much and the female buckle is threading the whole way onto the tie rod, look at this pic again:
now I could remove the tie rod itself and have it threaded deeper and shortened... I'm thinking that is a pain considering I don't really have the tools to do that.
Thought now is shorten the female buckle a bit and the male end of the heim a bit for some adjustment to bring the toe back in a bit... I don't need that much adjustment and before I run off and have the tie rods machined I'm going this route. I'm thinking about a 1/2 inch off each will do the trick.
left the car in parts for tonight and will go trim down the rod ends tomorrow then post results.
People that wanna still run the stock pick-up pointsYou could drill out the factory pick-up point to 14mm ID and run these no problem... I don't think you would need to trim the buckle or really do anything but the drilling... I gave the tapered bolts that came with the kit to Miro to take to VIR this weekend as back-ups just in case -but when he is back I'll test fit them, this might be a bolt on affair -but we'll see.
OK I'm beat hope this helps some people out.
