I've already lunched my N/A diff by wheel hopping and now that I've got a T2 I'd like to keep it intact. I'm planning on doing the rear bushings, dtss, and a pinion snubber, but is there anything else that I should do? Rear diff mounts? Subframe bushings? Any spherical bearings? Should I go for delrin or poly?
I have poly everywhere on my datsun, and I could hardly tell a difference in noise, but it felt a ton better to drive.
Also, will s4 calipers and rotors bolt onto an s5 subframe? I've got an extra s5 and would like to do all the work to it and then swap it out in an afternoon.
