what a few Sa/FB guys have done is to use the flush or bubble headlights from the FD. It is close in size and requires a little bit of modification. If you are good with fiberglass then I say go this route. I am making my own lights now after failing miserably to align the FD bubble lights I got. they are slightly canted compared to our straight lights. When I cut the corners off and added my own corners I fudged the bubbles and don't feel like grinding them down when I can glass a new set. I will probably use the clear part as a plug to make my own with 1/8 plexi. the trick with plexi is to gradually heat it, I start off with 10 minutes at 100* and go up in 50* increments for 10 min each till it gets to 300. Any hotter will cook them and any faster will bubble them.
Hadn't planned on it. As long as the 5.3 lifters look good I had planed to use them. Any reason I shouldn't?
