Drilled and tapped the block for the F-body alternator mount.
mounted manifolds.
Installed balancer.
Got the belt routing and size figured out. Just waiting on an idler pulley to finish that.
Coilpacks and plugs done
120lb Fuel injectors installed
Aem EMS assembled in the 6cyl PCM case. (Picked up the whole PCM for $20)
Tapped the heater plugs for the water pump. Also drilled/tapped a 1/8t hole on the low side of the thermo housing for the steam port return. Just waiting on the plugs/fittings.
Had to drop the driver side coilpacks about 2" to clear the -8 fuel fitting I installed. Worked out well, I was able to use the f-body spark plug wires I had after lowering the coils.
Going to use LT1 plug set on the passenger side.
Random inter-cooler shot. (31x12x4)
From when I had it outside. Looks like I'd have tons of room for headlights if I just left the bumper off...
