March 16, 2025, 04:26:50 PM
Author Topic: 1979 SA RX-7 LS Turbo Build (8.93 @ 153)  (Read 179010 times)
Offline N2v8fcs
Re: 1979 SA RX-7 LS Turbo Build
« Reply #45 on: October 28, 2012, 11:58:19 PM »
First numbers marked by the ** are all "12".
were all the parts needed when swapping to this cam?
Thinking of using this cam for my 5.3 turbo build.
:drive:
Offline N2v8fcs
« Reply #46 on: October 29, 2012, 03:40:22 AM »
Do you have the part number for the "C" 3 bolt, 1X cam sprocket ?
:drive:
Offline forcefed86
« Reply #47 on: October 29, 2012, 10:27:37 AM »
Page 3 lists the parts necessary except the 3 bolt 1 Tooth cam gear. I don't know the GM part off hand. I Ordered a 2005 GTO timing set from the local auto parts store for $38. Came with both timing gears and chain.    :cheers:
Offline forcefed86
« Reply #48 on: November 23, 2012, 12:13:33 AM »
Made a little progress.
Cleaned and did a speedy port job on the 317 (6.0) heads. Took the hump down in the intake runner,cleaned up the bowls, port matched the lower half of the exhaust port and trimmed down the valve guides.
Leaving the rough cut "port" job to create turbulence in the airflow.
New PAC1218 springs installed. These heads were run by a friend last year. Carb'd E85 setup. You can see the black tar goo all around the intake valves and ports. Hope to get the long block put together this weekend.
« Last Edit: November 23, 2012, 01:12:30 AM by forcefed86 »
Offline Burntz
« Reply #49 on: November 23, 2012, 08:32:16 PM »
Isnt that why you're supposed to run regular gas through it everyone once in awhile? To get rid of those black goo deposits from e85?
« Reply #50 on: November 23, 2012, 08:37:10 PM »
Just run some Seafoam or GM Top Engine Cleaner.
Offline SSjon
« Reply #51 on: November 23, 2012, 08:40:10 PM »
I wonder how that Zmax would do with the black goo
L33 T56 8.8
Offline forcefed86
« Reply #52 on: November 23, 2012, 09:30:54 PM »
I've tried it all. Nothing stops it completely. It's It seems region specific, not everyone has problems. I run e85 in 3 of my cars and they all have issues. I've tried mopar CC cleaner, seafoam, lucas FI cleaner, running reg gas etc...Even the lower blends do it. I run E50 in my daily and the injectors and intake looked like crap. Even the valve reliefs in the pistons had that gunk in it. I'm going to retune it for E30 this winter and try that.
« Reply #53 on: November 24, 2012, 12:44:09 AM »
Wowza.   I had my intake off a while back and there is just a slight brown tint to everything, NOTHING like that.   My injectors looked spotless.   I'm E85.
Offline forcefed86
« Reply #54 on: November 25, 2012, 07:48:57 PM »
Long block is pretty much together...
LS2 Timing cover w FWD cam pick-up is done.
ARP stud kit and LS9 7 layer MLS Hg's are all in and torqued.
Turbo oil supply done.
Waiting on drill/tap set to finish up oil pan drain.
« Reply #55 on: November 25, 2012, 10:05:45 PM »
it is the same shit i was getting in my filters
never saw it on the valves since i spray some water/meth
Offline forcefed86
« Reply #56 on: November 25, 2012, 10:58:11 PM »
Yea it's all over my motors. Sticks to the piston faces as well. It's like scraping syrup off the pistons. Good stuff... Don't mind that HG...I'm a professional.  :scratch:
Soaked the cylinders in mopar CC cleaner over night and it pretty much wipes out. Defiantly not oil though... it's sticky.
Offline forcefed86
« Reply #57 on: December 02, 2012, 09:49:03 PM »
Had some crazy unseasonable warm weather in KS today. (72*) Pressure cleaned and painted the engine bay.
Before.
After.
« Last Edit: December 10, 2012, 09:35:22 PM by forcefed86 »
« Reply #58 on: December 03, 2012, 10:53:44 AM »
Lmfao on the hg...
Bay looks good, you plan on swapping to a rack n pinion ever?
Offline forcefed86
« Reply #59 on: December 03, 2012, 11:50:11 AM »
Lmfao on the hg...
Hard to say at this point. The few companies that make bolt-in racks are very proud of them. Won't be fabricating one from scratch at this time. I’d like to see how this one handles at speed first. Planned on running quite a bit of neg camber to help keep it straight. If it still feels “off” I may end up with a tube front end and new suspension.
The steering linkage was dropped 2” to clear the oil pan. Screams safety.  :D
« Last Edit: December 03, 2012, 11:57:45 AM by forcefed86 »
