I recently changed to E-85 and i can tell you that when my car went into the mid 10's afr (gas range) I would have a issue with the car ramdom breaking up. I was an issue with my wideband formula once i fixed this and got my afr to 11.8-12.0 the issue went away. Also dont rely on specking of the plugs with E-85, due to the lower carbon build up from e-85 you may not have any carbon to knock off the piston and on to the plugs.
Where is your 02 sensor located? I was getting false rich readings when I had mine in the manifold. Moved it to the muffler tip and it read quite a bit leaner. I know Scottie and a few others run on the rich side with no issues. I had planned on leaning it out a bit on the dyno.
Do you use your knock sensors? Mine were going bat shit at 1-2psi and pulling a ton of timing. I ended up shutting them off. I was seeing 3.1v (5v is max) or so on the 8psi pull. I assumed this was just due to the solid motor mounts and or noisy glide sending odd ball harmonics through the block.
I was thinking I’d wedging my WG open to get little to no boost. Then datalog what’s considered a “normal” amount of noise (voltage) on my knock sensors. Then setting the sensors up to pull timing if that normal point is exceeded. But if I'm already getting 3+v the engine may just be to noisy to pick up knock properly.
I was ASSuming I wasn’t detonating at 8psi, but I don’t know how I’d tell if I can’t use the plugs. Pretty sure speckling (at least major detonation) is the result of alum specks from the CC. Defiantly saw speckling on my E85 buick and 4g63. Can see a tiny bit of pitting on the pistons usually as well.
This is 34psi and to much timing on my e85 4g63.
On a side note...
Swapped in a larger area filter. Still on the small side, but I'm claiming average now.
