Quote from: Pez on February 06, 2012, 09:40:27 AMQuote from: ls13rdgen on February 06, 2012, 08:29:36 AMQuote from: Andrew R on February 06, 2012, 02:28:14 AMShit -I can't get 10k for mine and I have way more into mine.mine looks a little more appealing to the eye and will probably run circles around youAlso, how do you get a 129mph trap speed with only 433hp and no spray? To get that speed on a 3000lb race weight car, you need at least 525hp, and that's with the best driver around and no wheel spin.I did 127 with 406 to the wheels 5x. Either it's doable or the dyno was off.
Quote from: Seve7 on March 20, 2012, 10:57:16 PMjust to let you know, if the lights are short at the end of the track the mph goes up.Think about that how is that possible. if that was case the 1/8 mph would be higher than the 1/4mph.
Quote from: ls13rdgen on March 20, 2012, 11:18:00 PMQuote from: Seve7 on March 20, 2012, 10:57:16 PMjust to let you know, if the lights are short at the end of the track the mph goes up.Think about that how is that possible. if that was case the 1/8 mph would be higher than the 1/4mph.I think he may mean the interval where your trap speed is measured . Also if they are out of adjustment that could cause poor trap estimations
