March 28, 2025, 07:14:32 PM
Author Topic: UPDATED! 404ci ls2 power expectations and new setup!  (Read 6910 times)
Offline csilvers1984
« on: February 04, 2012, 05:57:12 PM »
UPDATE!! After deciding to keep the car and finishing the build I also decided to make a few changes!! The new setup has almost everything changed besides the rotating assembly!
New setup!!
404ci ls2 TSP shortblock
Scat/eagle -2cc diamonds
LSA ported oil pump
New cam 247/262 .632 .596 115 +4
Powebond 25% UD pulley
All new gaskets and seals
New top end where I spent the $$$ haha
TFS 235s 64cc for 11.89 comp
Yella Terra non-adj roller rockers
Ls9 head gaskets
Fast 102/102 ported and port matched to the 235s
Return style -8 fuel system with A1000 FPR,billet rails and 400lph walbro
Ford 42# green tops
Samberg rad/intake with ls7 maf elbow
Hinson/stainless works 1 7/8 LTs
3in or/y pipe with 4in single dynomax bullet.
Also changed to the following..
McLeod RXT twin with 18lb spec billet flywheel
Still no AC/PS,HVAC
Samberg 8.8 straight axle with 3.73s!
OLD SETUP
PRC 66cc stg 3 317s 2.08/1.60 324 cfm@.600
.051 gaskets approx 11.4 comp
Fast 90/90 ported AND port matched to heads
Samberg OTR intake with ls7 MAF
42lb green tops/walbro 400lph
Bottom end...
Ls2  block
Eagle crank scat rods
Diamond TSP 4.010 -2cc flat top pistons
TSP giant cam 248/254 .615 .622 114-LSA 110-ICL
Powerbond 25% UD pulley
3in y-pipe into 4in single with 5in round bullet muffler
No AC or PC
That's the main build specs and anything can be noted if need be.
I'm hoping for close to 500rwhp.
« Last Edit: April 23, 2012, 12:12:21 AM by csilvers1984 »
Re: 404ci ls2 power expectations?
« Reply #1 on: February 04, 2012, 06:15:35 PM »
shouldnt be a problem
Online MPbdy
« Reply #2 on: February 04, 2012, 06:20:09 PM »
Its always good to be conservative, but that thing better make all of 500rwhp.
Make sure you get some good valve springs on there and do something about the rockers.  Either have CHE bush them, comp trunion upgrade, or some aftermarket ones.
« Reply #3 on: February 04, 2012, 06:39:17 PM »
Trunion upgrade is being installed and valvesprings were tested.
Offline Jordan Innovations
    • Jordan Innovations
« Reply #4 on: February 04, 2012, 08:01:06 PM »
500whp should not be a problem.
Offline Sabre002
« Reply #5 on: February 04, 2012, 08:17:58 PM »
I would hope so man.  I'm looking for 525 out of my little 403 lol
Josh
Jsmit295@mazdausa.com
Offline Demon
« Reply #6 on: February 04, 2012, 08:46:35 PM »
500whp NA is a tricky sombitch. Our baby 393 with the fast 102 and cnc'd 243's and 247/251 cam only made 507.
I bet now with out bigger cam it might make 530ish.
Offline Sabre002
« Reply #7 on: February 04, 2012, 08:49:07 PM »
Whats your new cam specs Demon?
Ed speced me 600/600 248/256 114+3
Josh
Offline Demon
« Reply #8 on: February 04, 2012, 08:56:24 PM »
249/257 .651 .651 109+3
Offline Sabre002
« Reply #9 on: February 04, 2012, 09:15:52 PM »
he seems to like just spliting the duration.
Josh
« Reply #10 on: February 04, 2012, 10:03:33 PM »
500rwhp does sound great but my trap speed will be the tale all.
« Reply #11 on: February 04, 2012, 10:39:23 PM »
amen, trap>>>>>>>>>>>>dyno
Re: UPDATED! 404ci ls2 power expectations and new setup!
« Reply #12 on: April 22, 2012, 08:24:32 PM »
Bump for new changes!!
Offline Sabre002
« Reply #13 on: April 22, 2012, 09:41:34 PM »
shits weak
Josh
« Reply #14 on: April 23, 2012, 12:16:27 AM »
shits weak
When you send my $100 winnings make sure to include the PayPal fees :)
