Progress has been slow, but such is life as we all know. On target now for the beginning of next season though
I may bounce aroung here a bit since a lot has been done since the last time I posted!
Everything is basically in place now and hopefully I can get the wiring complete over the next few weeks along with ordering all the plumbing materials.
Still the core engine in the car but everything is coated and accounted for now! The new engine is all machined and ready for assembly but I'm waiting till last for that.
Lots of improved racing goodies in here once again.
Shot of the front grille/air dam
Exhaust came out pretty good, it's all cerakoted glacier black now to help with temps and discoloration. The intake and such is regular cerakote ruby red.
Now for the item that I spent entirely too much time and effort on. Started out with a template that changed about 10 times, 3d scanned, modified, sent to a friend that does this sort of thing for a living - fea, testing at 1klbs load in simulation with esses, 20g shock load and several other things to end up with this in .500 6061.....
I beveled, knife edged and rounded everything by hand with a router and 3 different bits, talk about a huge ass mess but the other option was to have things cnc cut and make them $2000 wing stands
Trunk area - fire bottle, fuel cell, accusump
During the interior process -
Firewall...
shot of the coolant tank as i was fabbing it.
battery and diff pump mounting
Mk60 abs, radio, ecu, pdm, disconnect, wb controller, brake reservoir and coolsuit cooler - the dash has quick fasteners and comes out in about 10 seconds.
Dash in its current state, need to put the usb connector for the aim pdm in the dash by the one for the haltech then its all there basically. You can see the rear view monitor up at the top as well.
Can slightly see the floor mount tilton pedals. Went with those versus the wilwood due to higher leverage.
17x10 wheels, toyo rr 255/45r17 for now - HP benefit with classing for the less sticky tire. 13" alcon rotors with wilwood superlites. Same as I had on the FC so good enough for this girl!
stock'ish rears
And here we are so far!!!
I know that was probably a lot in one bite but if you're curious about something I'm happy to answer! Starting to get motivated again now that life stopped !@#$ing me
