Well things worked out pretty good this past weekend, I finally have a car i can drive again. Second gear accelleration is great when tires are hot, rough surfaces are not a issue any more, car transitions well, tons of rear grip - I am in love with that.
Things to work on - car has a good deal of push mid corner and corner exit unless I over power it. I can set the front end under braking and turns in great but then it goes away. Rear braking has definetely deteriorated some due to increased weight transfer, I feel some of that is also from the valving not being correct in the shocks for the softer springs.
So after getting pressures dialed in after the first couple runs I worked the absorbers some, got a little improvement from that. Rear bar is still disconnected and front bar set in the middle setting. Now I know you guys are wondering why I didn't start adjusting bars like crazy, which I wanted to do but I felt it was better for me as a driver to work on myself first since the whole car was basically new again, for the second time haha which I'm glad I did do but also it ruined my weekend a little sooner than I hoped as I corded the fronts from drving through the understeer. Now one other thing to note is these tires were old and the fronts were definetely older than the rears so some of the push was part of the tires. I didnt want to throw on fresh tires until I felt the car was somewhat in the ballpark.
I got one vid as friend wanted to ride along on the second session on saturday and brought his camera which I'm he did, showed me how far my line was off on some of the corners
You'll also hear me mentioning braking issues as at end of the video as I lost pretty much all the front brake pressure due to air in the lines, pedal went pretty much to the floor but the rears still functioned thankfully. It was kinda mushy going through that whole session but once I started to pick up some speed it just went completely away
Thought I had it bled pretty well but once I got back in the pits and bled them again they had a loooot of air in them front and rear, pedal felt great the rest of the weekend afterwards. So enjoy the vid!
https://youtu.be/TEqIMcfCZuc
