March 14, 2025, 08:57:49 PM
Author Topic: Akina's build  (Read 258329 times)
Offline 1320king
Re: Akina's build
« Reply #495 on: March 02, 2015, 05:05:08 PM »
what wheel hub and wheel are you using.
Re: Akina's build
« Reply #496 on: March 02, 2015, 07:12:44 PM »
Your car is so nice it is stupid Erik. How are those Bimarco seats working out?
You are going to love the shiftlight. It has been very helpful for me.
Re: Akina's build
« Reply #497 on: March 02, 2015, 09:22:42 PM »
Looks awesome!
Re: Akina's build
« Reply #498 on: March 02, 2015, 09:50:09 PM »
Geeze that thing is nice.   Just beautiful.
Re: Akina's build
« Reply #499 on: March 03, 2015, 12:35:41 PM »
NRG slim hub with 2.5 quick release and Sparco R375 wheel
Thanks Ash. The seats have been awesome so far for what little drive time I have had with them, really looking forward to using the shift light.
Thanks guys, I'm really happy with how its turned out so far, hopefully the shift light curves my want for a AIM or DASH2 instrument cluster haha
Re: Akina's build
« Reply #500 on: March 11, 2015, 05:37:31 PM »
Finally getting a move on with getting things wrapped up before the season begins. All the parts finally arrived for the mazda yesterday after weather delays :(  looking forward to getting the car finished now. Picked up the new trailer which I am excited about, its my first "brand new" trailer. Its finished on the inside with wood paneling, doesn't look bad, but I am refinishing it to my liking with white aluminum paneling, raw aluminum trim and black short pile automotive carpet. Already got a winch, deep cycle battery, solar charger for the roof - mainly to maintain the battery, LED interior flat panel lights and some other odds and ends, also got the materials to build the cabinets in the front v nose area out of aluminum. Really look forward to having this at the track for the whole family.
Re: Akina's build
« Reply #501 on: March 16, 2015, 12:02:29 PM »
Well after lots of work this weekend I got the headers in the car finally  :( The improved racing cooler adapter fit great, very happy with that. The Ronin engine mounts would have worked awesome and been perfect had my car been designed to work with them from the beginning or not trying to use these headers and my original drive train positioning together.
Got the new mounts in and ready to bolt up, realized the bolt holes were off by almost a inch, choices were modify the mounts or change the trans positioning, drive shaft length, shifter mounting.... the mounts were getting changed. Had to cut the passenger side upper mount's base plate off and relocate it forward, not a whole lot of work and pretty much cant tell anything was done, drivers side was another story. None of the drivers mount would work. After notching the frame for the #3 primary to clear, the lower engine mount portion hit the #1 primary tube. So i sectioned the lower mount and moved the mounting face forward, built a whole new upper mount that roughly looks like the Ronin, just not as nice looking with laser cut holes :'(, that is angled and notched to clear the #1 primary tube. In the end it turned out ok, just have to finish putting the car back together, change the front portion of the exhaust and weld on some v-bands. The more I look at the mount I made I think I'll take it back out and cut the holes in it to match the original Ronin one, clean it up a little more.
Still need to get the trailer ready and finish tuning the car, running out of time for the first event  >:(
Offline Turbotronic
Re: Akina's build
« Reply #502 on: April 29, 2015, 03:16:03 AM »
Have you corner balanced it since the supercharger install? I'd be curious how it balanced out. Gorgeous FC, BTW. Your car is top notch, I've taken notes for my build.
Re: Akina's build
« Reply #503 on: May 02, 2015, 10:32:20 PM »
Thanks turbo! I just got my own scales today actually so i will be doing full adjustments starting tomorrow as I have to put some weight in the car to make class spec. Supercharger is gone now as will be a lot of things as i finish the cage and start preping the car to run ST2/TT2. So far I detuned it a lot but still makes tons of power, hell its over 400ftlbs at 2500 rpm and runs out till 6700 but it just doesnt make the cool peak numbers everone judges haha i can literally run a track in 4th the whole way if i wanted lol and its a lot more fun racing with a larger group versus yourself and maybe one other guy.
On another note I had a great time at gateway last month, car did good and so far been working the issues out that i run into. RPM is this month on the 16/17th so im preping for that currently. Got new livery for the car that I will have installed next weekend, i think it looks good so far. Will post up some pic's later. So far this season is starting better than last!
Re: Akina's build
« Reply #504 on: May 02, 2015, 10:40:40 PM »
Here's a current bay shot....
Offline Geoturbo
Re: Akina's build
« Reply #505 on: May 03, 2015, 02:09:08 AM »
WOW!! This car is far beyond awesome!
Re: Akina's build
« Reply #506 on: May 03, 2015, 10:39:51 AM »
No more AC?
Re: Akina's build
« Reply #507 on: May 04, 2015, 06:07:15 PM »
Condensor took a shot from a rock on the track so I just f-it and pulled the whole system, its in a box for the moment, may or may not put it back on - was worth 40lbs off the front end.
Offline Sho Amo
Re: Akina's build
« Reply #508 on: May 04, 2015, 03:13:17 PM »
I knew something was missing but couldn't quite put my finger on it. I guess since the s/c is gone I just thought it all looked kinda empty.
[Sold] '90 GTU LS1/t56
Re: Akina's build
« Reply #509 on: May 04, 2015, 09:42:53 PM »
Welcome to adding lightness! You have pulled what, 200 lbs of the front end at this point?
