Thanks guys!
Well round one of the new aero didn't go as planned on . We had a good amount of rain, standing water on the track for the first day and all i had was my scrub r7's haha HYDROPLANE
Car felt ok when things dried out, rear high speed grip wasn't what i hoped for and ended up with the wing at like 22* AOA which caused major drag, could see the mph was down but it was the only way to somewhat balance the car at speed. Front splitter design was tough as nails but heavy, like 30lbs heavy so that was frustrating but it was a good template. Front end would turn in at any speed, so at least we had that going for us. Ended up about 4 seconds off the fastest over all and second place in class, went home with some knowledge gained.
Round two! Change everything! haha
I re-designed the front splitter from 5mm alumacorr and designed larger end plates. I highly recommed this stuff for aero, its awesome. Highly rigid and very very light, about $120 a sheet so very reasonable cost wise. Rear wing moved up 7" above roof height and 4" behind the bumper. Time to find out what it does! Next up Hallett summer shootout in oklahoma --- 6-24\25
Amazingly aero settings out of the box were damn near spot on the first day at Hallett, wing was set at 16* AOA and first run out the car was VERY neutral. I was pumped! Set tire pressures and just focused on me adapting to the new grip for the weekend. Couple of notes......Pad knock back was rearing its head again though, I think I need to just torque the front wheel bearings again but not sure. New brake pads from G-Loc are awesome, five stars for that and glad I made the change.
Took 1st place in class both days, corded the fronts and kept up with the radicals/aero cars in the unlimited class. We are really starting to gain ground! No records broken this weekend but I didn't expect it, untested stuff and old tires. Time to put fresh hoosiers on and go to hastings, to bad its not until sept 1st
One small note I did make a new shifter knob from delrin, really like the feel of it, adds a little weight to the throw.
Video from Hallett so you can see me work my knob.....
https://youtu.be/b9KUfjHx4RI
