Thanks guys!
Got it up and running, rough tune was good enough to run it in on jack stands for 20 minutes, no leaks but the new billet water pump pulley I pressed on walked right off the shaft when i whacked the throttle, by shear luck I shut it off at the same time my friend seen it come off, so no major damage done thankfully. Serp belt did jump off the ps pump and cut into the ps pump tank. Second time this has happend so I made a shield for it out of aluminum the exact shape of the tank, epoxied it to the front and painted it flat black. If it happens again it will have to go through 1/4 plate first
Bought a new water pump and welded on the steel pulley it comes with so it wont happen again.
Car runs awesome, still breaking it in as I only got to drive it for a few hours last sunday night. New trans is fantastic, leaps and bounds above the old t56 - the t56 is crap compared to one of these, I am still in amazement as to how great it shifts. Only small problem I had with it was the vss went bad and I had to get a new sensor for it.
New fuel system works perfect other than the pump resonates really bad in the car - sounds like a blender in a 55 gallon drum - i need to take a video of how horrible it is right now. Spoke with Fuelab this week and got some ideas how to isolate it and should make a big difference since my pump and sending unit is pretty much hard mounted to the tank.
Will have some new pics this weekend!
