March 18, 2025, 08:14:27 PM
Author Topic: HELP! LS1 misfire and idle surge  (Read 7074 times)
Offline VX8
Re: HELP! LS1 misfire and idle surge
« Reply #15 on: January 06, 2014, 07:37:30 PM »
Maybe a slightly bent valve causing the valve to hang open or stick closed.
Thats my 2 cents.
You also mentioned you straightened the pushrods. I would never run a restraightened pushrod, you are asking for trouble.
Kev, I was thinking along those lines also.  I pulled the heads and everything looks good.  I removed the springs, and all seem to be in good shape along with the valves.  None sticking for sure.  Do they all seat properly?  I am still looking into that.  I have to reassemble and test with a liquid to see if any are leaking. I hear you on the pushrods and am going to order new ones before I reassemble the engine.  Thanks!
