March 18, 2025, 08:14:40 PM
Author Topic: Hot Rod Magazine makes 1200HP on "junkyard" 4.8L... stock bottom end!  (Read 25776 times)
atomicsix
  • Guest
Re: Hot Rod Magazine makes 1200HP on "junkyard" 4.8L... stock bottom end!
« Reply #15 on: August 25, 2011, 03:35:28 PM »
This is a stock 6.0 we only installed a cam/spring package in, with a 88mm power adder.
Offline 383mazda
« Reply #16 on: August 25, 2011, 10:14:47 PM »
holy cow!  nice run.  650 rwhp would be great - it' just that a lo of guys I've spoken with doing the "junk yard turbo truck motor" builds have been well north of 650 with gapped rings and stock internals.  1300hp would be a fun run down the track!!! :D
'86 GXL
For now: 383ci, Q-jet carb, vortec heads, 2004r tranny, NA rear = 305 wrhp
Sitting in my garage: LQ4, LS6 intake, Ported LS1 TB, TII rear end
On the wish list still: TC76, engine lift and warm weather!
Offline skinnies
« Reply #17 on: August 26, 2011, 06:54:47 AM »
E85 and over 800 rwhp on setups with stock gap, up as high as 24.5lbs of boost too on one setup.
1st gen rx7 -  76mm junkyard 5.3, 8.65 at 167.9, first stock shortblock ls in the 8's!
1985 Ford LTD - 9.7 at 144, junkyard 5.3/76mm on 235 drag radials, 10.25 at 142 on street tires(no drag radials)
Offline dark-one
« Reply #18 on: August 26, 2011, 05:44:36 PM »
Well I mean I dynoed 673 on a stock ls6 with rod bolts cam pushrods and springs....I'd like to go more but it prob wont hold.  I think these iron blocks are much more rigid and keep everything inline.  I might just have to buy a truck motor and crank the boost up.  :D   I just don't wanna dump the funds into a elaborate built motor in a IRON BLOCK...GETS $$$$$ rather quick
Offline DavidPHumes
« Reply #19 on: August 26, 2011, 05:51:17 PM »
My built LQ4 is only going to cost me $3,000 parts and labor to build... not including the stock motor so we'll say $4k.
That's not bad all things considered... I mean it will handle 1,000HP all day long when it's built. Just my opinion...
Offline dark-one
« Reply #20 on: August 26, 2011, 06:43:34 PM »
What rods and pistons did you go with?  and stock crank I assume...no real need to replace it unless you want more cubes
Offline DavidPHumes
« Reply #21 on: August 26, 2011, 06:55:23 PM »
Callies rods and Wiseco pistons... and yeah I stayed with the stock crank. I won't ever push this car that far
Offline Seve7
« Reply #22 on: August 26, 2011, 10:53:26 PM »
i wonder how fast it would melt once it had a real load on it
