March 18, 2025, 08:14:35 PM
Author Topic: "semi solid" FC front diff mount  (Read 3780 times)
Offline theantirotor
« on: April 24, 2011, 04:33:25 PM »
Saw a thread on the club a minute ago that had a different type of front diff mount in it.  Seems like a pretty good idea, besides the fact the poster may be a scammer.
http://www.rx7club.com/showthread.php?t=938333
Seems like it could be a good design.
:bacon:
Offline Rayminator
Re: "semi solid" FC front diff mount
« Reply #1 on: April 24, 2011, 05:13:22 PM »
You will still rip the stock mounting tabs off of the cross member. Pinion snubber or not. Over priced, for a home brew item.....put some drag race launches on it with a slick.
« Reply #2 on: April 24, 2011, 05:33:50 PM »
As was mentioned in the thread reinforcing the tabs is all but a requirement.
:bacon:
Offline ChippeRX7
« Reply #3 on: April 24, 2011, 06:28:19 PM »
Maybe Ronin could fab something similar up.
I know I would be interested!!!
1990 GXL 5.0 w/ ported gt40p's and a T-5  ::)  . . . Dont hate me cause im poor :(
UNDER CONSTRUCTION
Offline V8-rx7
« Reply #4 on: April 24, 2011, 07:30:41 PM »
I could build you something like that but I really don't see the point.......
« Reply #5 on: April 24, 2011, 07:32:57 PM »
Why not?  If it has to do with the 8.8 IRS setup coming out, that is not going to be a viable option for everyone.  Don't take that as trying to slam the 8.8 setup at all as I would like to have one for myself once they are in production but I am sure there are going to be people that won't want to go that far.
:bacon:
Offline ChippeRX7
« Reply #6 on: April 24, 2011, 07:52:51 PM »
better feel?
IDK seemed like a good idea, im running ford power so i wont be breaking anything  :D ::)
Why would it not be a good idea? :confused:
seems like an upgraded semi-stock design.
Im sure you guys have more experience with this so let me know whats up dudes :yay:
UNDER CONSTRUCTION
Offline bikedad
« Reply #7 on: April 24, 2011, 08:28:30 PM »
Here's what happens when torque is applied to the differential via an 8 rotor motor. (with pinion snubber installed):
Here's a very simple solution to prevent previous carnage. That tab will not hold even with a pinion snubber. There is very little drive line noise. Some, but not terrible at all.
http://www.norotors.com/index.php?topic=3659.0
Don Teifke  :drive:
[smg id=8489]
-----John Wayne-----
Offline Dr1ft1ng0wns
« Reply #8 on: April 25, 2011, 12:09:27 AM »
I was going to say, wouldn't a ray device do the same thing for much less and be less complex?
83 K5 Blazer on 37's
01 Civic DD
Offline Rayminator
« Reply #9 on: April 25, 2011, 06:25:57 AM »
Correct Weed Hopper, plus it helps with weight transfer.
I think that new mount is ok, don't get me wrong. But it will not solve the total problem.
« Reply #10 on: April 26, 2011, 02:06:23 AM »
lol. I'll be building one of the "Ray devices" here in the next week or two, just got my polythylene diff mounts, so i can put in the lsd rear.
01 Civic DD
