Hi all, starting to research clutch hydraulics and I've got a few questions:
1) Is it worth it to replace the slave cylinder as preventative maintenance? I don't think anything's wrong with mine and there's only 46k on my pullout, but I'm thinking it might not hurt to replace it while everything's apart since it looks like kind of a PITA to do once the car is put together. Do these have a history of failing fairly quickly or spontaneously, or would I be wasting my money?
2) What kind of fitting does the LS2 slave use? I know LS1 slaves use a proprietary QD, what about the LS2s? I'm trying to figure out what connections I'll need on each end for the clutch line between the Wilwood 7/8" MC and the LS2 slave.
3) What exactly is it that Hinson 'modifies' on their Wilwood 7/8" MCs? For what it's worth, I'll be purchasing Pez's firewall mount and Wilwood MC whenever it's available, I'm just curious what 'modifications' people are describing when they refer to Hinson's kit.
4) What are people's opinions regarding speed bleeders on the clutch, and what are the recommended brands/setups people are running?
As always, thanks in advance
