March 15, 2025, 11:10:58 PM
Author Topic: Samberg V2 radiator  (Read 3665 times)
Offline AHarada
Samberg V2 radiator
« on: November 26, 2017, 07:01:28 PM »
For sale is my used Samberg radiator with about 5,000 miles on it.  The radiator seeped a small amount of coolant like many have, but after using GM sealing tabs, it held pressure and didn't leak at all.  A leak was repaired professionally by a radiator shop in the lower driver's side, so the shroud was cut out and rewelded. Includes radiator, shrouds, and mounting bolts/grommets.  For a complete setup, you will need to add fans, hoses, expansion tankl, and fittings.  Asking $500 in socal.
[smg id=6954]
Offline BlnLs1/rx7
Re: Samberg V2 radiator
« Reply #1 on: December 23, 2017, 03:25:00 PM »
Will it fit an FC?
Offline AHarada
« Reply #2 on: December 27, 2017, 12:29:03 AM »
Probably won't fit an FC without modification.
[smg id=6954]
Offline AHarada
« Reply #3 on: December 19, 2020, 11:25:00 PM »
Bump. Still have this, now located in Olympia WA
[smg id=6954]
« Reply #4 on: December 28, 2020, 02:08:02 PM »
PMed
Offline AHarada
« Reply #5 on: January 02, 2021, 01:57:53 PM »
Sold
[smg id=6954]
