March 18, 2025, 08:14:09 PM
Author Topic: Double adjustable front struts FC  (Read 1482 times)
Offline Grumpy
« on: March 09, 2019, 03:50:49 PM »
Ok car has plenty of power now I have to get it to the ground. What are FC guys using ?
Dan
AKA "Sleeper6"
9.999 @ 135.96
Buick GN V6 Turbo
8.8 Ford rear end. 308 gear.
200 R4 with a LU converter
Drag Radials
3324#s
Offline SuperSlow
Re: Double adjustable front struts FC
« Reply #1 on: March 10, 2019, 07:45:49 PM »
A lot of guys seem to do well with kyb singles and stock shocks.
I opted for the 3rd gen f-body front coil over conversion, there is a write-up on it here somewhere. Not sure if I got the shock to hot or what but there was a lot left to be desired. With QA1 single adjustables set to full loose I don't notice any "floating," while cruising and the nose doesn't come up nearly as fast as I would like it to on the street. Does fine at the track tho.
It's something that is on the list to revisit at some point.
Offline SuperSlow
« Reply #2 on: March 10, 2019, 07:47:29 PM »
A buddy of mine does pretty well with tein coil overs. Hooks on just about any surface with a 383 sbc, th400 and a mickey thompson 275/17 radial.
Offline Grumpy
« Reply #3 on: March 10, 2019, 08:14:10 PM »
ya i couldn't find it in a search.
Dan
AKA "Sleeper6"
9.999 @ 135.96
Buick GN V6 Turbo
Drag Radials
3324#s
Offline SuperSlow
« Reply #4 on: March 10, 2019, 08:38:50 PM »
Offline Grumpy
« Reply #5 on: March 10, 2019, 08:46:45 PM »
thanks  :cool:
Dan
AKA "Sleeper6"
9.999 @ 135.96
Buick GN V6 Turbo
Drag Radials
3324#s
