March 18, 2025, 11:44:39 PM
Author Topic: Second chance at life as a drift car - Team Breaking LS FD  (Read 5973 times)
Offline W.tungsten
Re: Second chance at life as a drift car - Team Breaking LS FD
« Reply #15 on: April 10, 2018, 08:54:42 AM »
Yup as DDv8 said we're kinda SOL for caster adjustment. My alignment bolts are maxed out. I was debating making a special offset bushing for the rear mount to try before going all in with a custom arm. I'm not sure it's worth the effort as it seems I need a TON more caster. It seems some others have done this with success:
https://www.rx7club.com/suspension-wheels-tires-brakes-20/custom-fd-front-camber-caster-bushings-941277/page2/
Attached below is a rough draft of a custom arm. It'd be waterjet steel that bolt on end would allow me to try one version with close to stock geometry then swap the 'lollipop' end with a high caster version. I'd love to do a machined aluminum arm and make it look close to stock but it would just cost an arm and a leg.
« Reply #16 on: April 10, 2018, 08:33:24 PM »
Looks like a wisefab arm which it means it will probably work. Can you use the FC ball joint?  Villans makes an adjustable one
Offline W.tungsten
« Reply #17 on: April 16, 2018, 11:02:13 AM »
That's exactly what I need except the FC and FD have different ball joints. FD is a taper and FC has a groove non-taper. Not sure the exact terminology.
« Reply #18 on: April 16, 2018, 02:33:55 PM »
Super Now sells a offset caster bearing off the shelf.
« Reply #19 on: April 16, 2018, 06:22:13 PM »
I know what you mean, there was someone on the club doing a spherical bearing version but not sure if it was ever finished
Offline W.tungsten
« Reply #20 on: April 16, 2018, 10:07:16 PM »
Oh whoa! Yes you're right! I may need to look into buy a pair. I actually just bought rod ends to start making some custom lower arms. Hmmm maybe worth doing both. THanks for the tip!
