March 18, 2025, 06:59:40 AM
Author Topic: Oil pressure and oil temp for ECU??  (Read 1474 times)
Offline BNR34RB26DETT
« on: February 08, 2018, 08:55:07 PM »
So im almost done wiring up my LS6 harness with F Body ECU
I have hooked up coolant temp sensor but i dont even see a pinout for engine oil temp and pressure.
1. is this necessary for ECU? If so, which pins do these need to go into??
2. I will be running Speed hut gauges in the dash with its own sensors and wiring. i do not need OEM sensor reading if not required by ECU
LS6 FD Build Video Series :drive:
Re: Oil pressure and oil temp for ECU??
« Reply #1 on: February 08, 2018, 10:51:48 PM »
No Oil Pressure/Oil Temp sensors required for the ECU on a 3rd Gen LS.   Run your Speedhut stuff and call it good.
« Reply #2 on: February 08, 2018, 11:07:45 PM »
THank you sir!!!
