March 18, 2025, 08:57:31 PM
Author Topic: S2000 push Button Start  (Read 7030 times)
Offline Badnews87@gmail.com
Re: S2000 push Button Start
« Reply #15 on: November 23, 2010, 08:14:18 AM »
ya im using a relay with the cig ligther powering the button but other than that i heard i could use the cruise control for power... cause the problem i have atm is just not being able to use my cig lighter for my GPS.... just want as much accesseries as possible since with the swap there not much left
If you dont know which way you  are going... any road will get you there!
Offline dream36realms
« Reply #16 on: November 23, 2010, 11:15:45 AM »
I hard wir in the gps and the radar. use a relay for both. Garmin sells a hardwire kit if you aren't comfortable with splicing. their plug in has circuitry in it. Run the wires behind the dash. it looks super clean.
日までに仕事および夜までに虐殺。
を下って、人類と
Offline Ericsworld
« Reply #17 on: November 09, 2016, 02:07:22 PM »
Wiring & Electrical Gurus:
I'm about to wire in a s2000 start button but wanted to clarify something. I'm following both the Revlimiter and RX7Club writeups for guidance.
However, in the revlimiter guide (http://www.revlimiter.net/mods/s2000_button.php), he cuts the Ignition wire in half and then wires one side of the wire to position 30 on the relay, and the other side to position 87a... What is the point of this and how does it work?
In the RX7Club guide, position 30 on the relay is simply tapped into the Ignition wire and 87a is not even used. Tapping also allows for the key start function to still be retained, which I like.
So I just wanted to clarify why revlimiter did it with both 30 and 87a.
