March 18, 2025, 06:59:42 AM
Author Topic: Are there any chassis harness simplification write ups?  (Read 3231 times)
Offline mdessouki
« on: July 02, 2016, 04:50:19 PM »
Looking to cut down on the front harness that runs from the firewall forward.
Thanks!
Offline DDv8
Re: Are there any chassis harness simplification write ups?
« Reply #1 on: July 02, 2016, 05:27:26 PM »
Which series?
Offline paul_3rdgen
« Reply #2 on: July 02, 2016, 10:46:57 PM »
I'm pretty sure he has an FD
93 RX7 R1 500rwhp
LS2, H/C combo... ARE drysump
Offline mdessouki
« Reply #3 on: July 03, 2016, 12:28:34 AM »
FD- Danzan had a post on this, but I cant find it...
Offline wompa164
« Reply #4 on: July 05, 2016, 07:59:22 PM »
What are you looking to remove, and how far are you willing to go with it? (ie: unwrapping the whole harness, depinning connectors)
Offline Gunnytron
« Reply #5 on: July 06, 2016, 02:46:59 AM »
I found that in the end it's just a case of using logic.
Unwrap the whole loom then take a connector that doesn't plug into anything anymore and trace the wires back until they join with another Wire, connector etc.
I know most jobs take longer than expected, but this still surprised me how long it took. I did relocate and consolidate the fuse/relay boxes to one place though.
Offline fastfalcon94
« Reply #6 on: July 06, 2016, 10:07:59 AM »
I didn't go crazy with my wiring. I know some people cut out all the wires. I found it was pretty easy to tuck stuff out of the way. This is what I did:
http://www.802projects.com/rx7wiring.php
Offline mdessouki
« Reply #7 on: July 06, 2016, 03:54:17 PM »
I'm want to cut/ de-pin as much as possible.  Using logic makes sense, but it would be nice to have a write up for questions (eg: do I need a diagnostic port? Doubt it but i'm only 98% certain)
Offline Gunnytron
« Reply #8 on: July 06, 2016, 05:30:39 PM »
I ditched the diag port if that helps.
Offline wompa164
« Reply #9 on: July 09, 2016, 01:35:29 PM »
Sorry if this sounds dickish, but if you can't be bothered to study wiring diagrams and make some of those decisions for yourself, you're probably not a good candidate for heavily reworking your wiring harness.
Offline Gunnytron
« Reply #10 on: July 09, 2016, 02:01:05 PM »
I was in the "dickish" situation when I started. I just went slowly and labelled both ends of any wires I removed in case I needed to put any back (I didn't). Wiring diagrams make a lot more sense the more you do it.
Start with the easy stuff like wires that go to sensors that are no longer needed.
The reason why there isn't really any write-ups is because it's a long drawn-out job and who can be arsed to do a writeup when you have to spend so much time doing the work. On top of that, most people have different setups. e.g. mine was RHD for starters, I kept the ABS and Airbag wiring and like I said earlier, I moved the fuse/relay boxes.
There were a few stages I went through and at the end of each stage I plugged the harness back in again and made sure I didn't mess anything up.
