March 17, 2025, 04:26:01 AM
Author Topic: Tricky's 1990 RX-7 FC 350 sbc  (Read 38128 times)
Offline trickygotmein
Re: Tricky's 1990 RX-7 FC 350 sbc
« Reply #150 on: April 14, 2014, 12:42:49 PM »
Next on the list is:  Install Radiator and Oil Cooler , Run Fuel Lines -6 AN , Run Electric.
:D     W A R   H O R S E      :D
Offline etizz
« Reply #151 on: April 14, 2014, 09:54:44 PM »
the shrouding is kinda the only thing i would be worried about. They might pull more but you want it to be pulling straight through the radiator and not pulling from just all over the place or push for that matter. The electric taurus has a shroud and is pretty power full. I find them all the time at junk yards for 20-30, then get your self a volvo 2speed relay for another 20-30 and your all set.
EDIT: Just remembered its a sbc not a ls1, the volvo relay wont work but there are plenty of dual speed controlers that will with a probe. Hell autozone i think has one thats not horrible and usualy in stock.
it will work, i've got an sbc with a volvo fan and relay wired to a switch, cost next to nothing from you pull and pay, keeps my engine cool no problem, itd be nice to have an auto setting but if budgets tight just turn on low speed and youll be fine, high speed for the really hot days. glad to see the 4x4 status is going away now that theres a motor in there lol. keep it up!
2005 RX8 4.8 TR6060 8.8 SINGLE TURBO
Offline Dr1ft1ng0wns
« Reply #152 on: April 14, 2014, 11:25:51 PM »
A temperature switch is only like 30 bucks from summit, automatically grounds when the motor hits a certain temperature and installs in the head. I've got two controlling the taurus fan in my sbc FC.
83 K5 Blazer on 37's
01 Civic DD
« Reply #153 on: April 15, 2014, 08:13:11 AM »
^ Thanks guys about the volvo relays with tarus fan. For now... I want the Old School look and function. I'm gonna run as much mechanical parts as possible. examples: mechanical fuel pump, mechanical fan, no power steering, no a/c , no heat, carbureted (no ecu). So im ordering a 15inch flex fan and see how cool she stays.  :cheers:
« Last Edit: April 16, 2014, 02:20:10 PM by trickygotmein »
« Reply #154 on: April 15, 2014, 09:43:31 AM »
Haha whatever makes you happy man, I'm the total opposite. If i could control everything in the car with a touch screen i would.
01 Civic DD
« Reply #155 on: April 15, 2014, 12:49:11 PM »
I like how mean the front end looks now  :D  I'm leaving all holes open for air flow except below flip ups I will have headlights. Leaving flip-up holes open for "rough look" and air flow.
[attachimg=1]
« Reply #156 on: April 17, 2014, 09:39:53 AM »
 :wave: It has been exactly 1 Year since I started my project. Just want to say Thank You to everyone on Norotors for all your kind words and advice towards my build !  :cheers:
