March 18, 2025, 05:02:43 AM
Author Topic: ECS pulley, MAF MAP Seonsors, Gauges, Catch Can, Meth, Wideband, Fuelab, LOTSSSS  (Read 1639 times)
Offline turbo-civic-si
Shift Light 30$
ECS progressive Meth Kit without a pump, Single Nozzle 190
ECS Novi 2000 3.25 6 rib blower pulley with belt brand new 100
autometer cobalt electronic boost gauge with sender unit.  120
GM 3bar 20$
ZR1 2.5 bar map i think it has been trimmed 20$
Wideband innovate with gauge 90$
LS6 MAF 60$
LS1 thermostat 30$
dakota digital Electronic FP and electronic Boost 220$
Catch Can 75$
FUEL Lab Fuel Pump 800hp I think tested once for 10 min 150$
My mom owned a RX7, I even learned to drive a stick on it.  After I was good at driving a stick, the RX7 went to a junk yard and I bought a real car.
-Richey
Offline Speedfab
I'll take both those MAP sensors and that fuel pump Richie.
Is the shift light adjustable/programmable for RPM?  Do I need any special senders?
If the answers are yes and no (respectively) I'll take that.
just so you know.  The ZR1 map was modified, I cut the side off of it trying to get it to fit in a LS6 manifold.  No luck :)  Will not effect the functionality.  The 3 bar is old school but worked dead reliable.  The Fuel Lab Pump is a voltage controlled pump NOT the PWM stuff they are making now that work with the electronic FPR.  This one can not be mounted IN TANK.  But you still can run a high and low setting obviously.  I really did only use it for maybe 14 min of run time while building my fuel system.  Thought about keeping it around for just a spare as insurance but I do have a trailer now.  Also if you interested I have the parts to make one last 2.5 bar LS6/LS1 plug and play MAP sensor.  I made one for my car and it worked like a champ.
If you want all those things shipping will be free for you my friend.  PayPal is RCBthree@gmail.com
-Richey
