I don't know much about who my niece's in-laws use for trans work down in UT, but they drag race too... I just don't keep in touch with them much at all...
better options: My brother used to know a guy down in Las Vegas, NV that knows glides well (ran a place I think was called 'the chevy shop' they built tons of stuff for drag cars back in the day).... I don't know if he's in the biz anymore. If LV is an option, I'll see if I can hook up contact info. If not there, he probably knows a place up in Boise, ID that will build it right as well...
I'm in Utah.
Also, the original trans held but the clutches were dragging so it made a grinding noise and burned everything up.
my 4l60E had the 3-4 clutch pack set up too tight and had an warped pressure ring which cause no oil to get through the plates, and it burned up in 1200 miles... just outside of the perfomabuilt 1 year warranty.
I took it to a local trans guru and all is well now.
