I have for sale is a TII diff. The guy before me took it to a diff shop and he had them "shim" it out to make it act like a spooled diff about 3k ago, you can def feel and hear the tires chirp and slip when taking tight corners, I have had it in my car for 1100 miles with no problems with it at all, when I got my car up and running I put amsoil in it, the old fluid looked fine. Im building my car for road racing so I didnt want a diff that acts like a spooled diff Im asking 150 OBO
Granny T56 to TII drive shaft, asking 200
Intake with K&N air filter that goes to the driver side down through the car right in between the headlight and fender well down into the brake ducting. 150
Speed hut gauges, with mounting. It has speedo, tach, volts, water, oil pressure, and fuel, comes with all sending units that I got with the kit when I bought it. The tach and speedo are 4 inch, others are 2 5/8ths. It also comes with the mounts that you see in the picture. I made the one for the speedo and tach and screaming88 made the center counsel area. I can paint both before sending them. Im asking 700 for everything.
I have a set of JIC coilovers, 2200 miles on them, I ran them for 1200. Asking 1100
After market sway bars, not really sure what type they are but they are a lot thicker then stock, comes with bushings and mounts, asking 100 each or 150 for both.
Hinson Premium Cooling System comes with upper and lower radiator hoses, radiator, cap, fans, and clamps, only 1200 miles on it asking 550
Granny swap kit for FC, comes with the motor mounts, and trans mount. The guy before me had a carbed 350 in it and for his headers to work on his carb 350 he had to modify the drive side motor mount. Does not effect the mounts at all with the LS. I can get some pictures if you would like. Im asking 250 plus shipping.
All prices are OBO and if you have any questions please just ask.
