March 17, 2025, 03:38:34 AM
Author Topic: FC rear suspension and starting alignment/ride height  (Read 6850 times)
Offline jwvand02
Re: FC rear suspension and starting alignment/ride height
« Reply #15 on: March 11, 2020, 03:17:19 PM »
I have the MMR rear spherical trailing arm bearings in my car and still use the factory toe eccentric and factory toe links.
Everything is mounted with solid bushings - solid heim subframe link, UHMW diff and subframe bushings, Solid front diff mount, PBM camber links, DTSS eliminator and PBM solid rear upper hub bushings. Suspension is silent, and it never has any wheel hop.
I was wanting to go with solid stuff but the makers of a lot of these things really seem to have dried up for the FC. There was only one ebay seller with solid subframe bushings and was quoting a delivery date of mid-april. PBM has aluminum diff and subframe mounts but they are all designed in some way to tweak the location of items for cars that are substantially lowered, which my car isn't (at least in the rear).
« Reply #16 on: March 12, 2020, 12:04:58 PM »
Yea the PBM stuff does raise the subframe and diff in the car. You can have spacers made to make up the difference and bring it back to "stock height" Or just wait for the delrin ones. I have seen a couple other places here and there, but those Ebay ones are the cheapest.
Offline jdm91t
« Reply #17 on: April 03, 2020, 11:01:26 AM »
Yes sorry just seeing this, those ebay ones that were linked earlier are the Diff and subframe bushings I bought. I'm finally getting around to installing everything this weekend. The whole rear end is out of the car and I'm taking it to my friends shop for some 20 ton press action. Should be back up and running next week.
93 403ci FD finally burning rubber :drive:
Offline jwvand02
« Reply #18 on: April 04, 2020, 11:38:35 AM »
I decided to change course and do a brake booster and MC first, so I would have had plenty of time to wait on the solid ones  :D damn my impatience
