Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Search
Recent Posts
Gallery
Search
Stats
Login
Register
This topic
This board
Entire forum
Google
March 18, 2025, 08:57:36 PM
The Track
Drag Racing
(Moderator:
Demon
Camber
Add to Reputation:
I agree
I disagree
Comment:
« previous
next »
Print
Pages: [
1
Author
Topic: Camber (Read 2346 times)
icey?
Pre-Staging
View Gallery
Camber
on:
March 07, 2013, 06:21:24 PM »
What are some of you guys running to get rid of some camber in the rear. My tires are getting ate up.
Logged
BeatTheTunaUp
Launching!
View Gallery
Re: Camber
Reply #1 on:
March 07, 2013, 07:13:20 PM »
I run -.5 in the rear, -1.5 in the front, with a .01 toe in front/rear and 6 degrees of caster. Seems to be a pretty good all around setup.
Logged
93 FD money pit
15 Ram 1500 Sport 4x4
96 Dodge Ram 4X4 Truck I wanted in HS
98 Baja 192 Islander 5.7 vortec On the water
digitalsolo
Administrator
Top Fuel
View Gallery
Re: Camber
Reply #2 on:
March 07, 2013, 07:17:01 PM »
Solid axle.
Logged
1988 Mazda RX7 - Turbo LS1/T56/ProEFI/8.8/Not Slow... sold.
lt1fc3s
In The Bleach Box
View Gallery
Re: Camber
Reply #3 on:
March 07, 2013, 10:19:09 PM »
If its a fc i just got these bad boys from powered by max. there shorter than the factory links to reduce the negative camber. none adjustable. $100.00 for the pair.
Logged
ilovemybike
Staged
View Gallery
Re: Camber
Reply #4 on:
March 07, 2013, 10:35:13 PM »
I just cut and welded the factory units....
Logged
86 Comanche LM7 Prerunnerish
88 RX7 LM7 T56 Ronin 8.8 IRS
84 Mercedes 300D Circle track coilovers
85 Merkur XR4Ti M50 HX35 big tires
zbrown
Top Fuel
View Gallery
Re: Camber
Reply #5 on:
March 07, 2013, 10:46:38 PM »
Quote from: digitalsolo on March 07, 2013, 07:17:01 PM
Solid axle.
yup, i got tired of eating tires too
Logged
rex388
Supporting Member
Staged
View Gallery
Re: Camber
Reply #6 on:
March 08, 2013, 05:24:09 PM »
Ya it took me one season to to realize I have to get rid of the irs
Logged
Print
Pages: [
1
« previous
next »
The Track
Drag Racing
(Moderator:
Demon
Camber
Jump to:
=> Drag Racing
