Technical Information => Electronics => Topic started by: rx7lee on February 20, 2015, 10:43:21 PM
Title: abs used to run speedometer
Post by: rx7lee on February 20, 2015, 10:43:21 PM
Can one of the front wheel abs sensors be used with a Dakota sgi-5 box to run the speedometer on a fd?
Title: Re: abs used to run speedometer
Post by: Skeltic on February 21, 2015, 04:22:13 PM
That sounds like something that would work
Post by: rx7lee on February 21, 2015, 05:52:47 PM
I'm thinking it would I just need to figure out how to find out how many pulse  pre mile the stock abs sensors are
Post by: gc3 on February 21, 2015, 07:21:04 PM
count the tone ring and multiply it by tire circumference speed
Post by: mdickw on February 23, 2015, 02:45:50 PM
Looks like the ABS wheels are 44 teeth (from looking at pics). That would work out to about 34k ppm for a stockish size. According to the manual, the SGI-5 should be able to accommodate that, though it does explicitly say not to connect to ABS sensors. I think that's more for liability than technical reasons. If you're still running ABS, though, it would be a bad idea to use one of the wheel speed sensors. The SGI-5 might sink too much current (but probably not), distorting the signal from the sensor. The additional wiring to get the SGI-5 onto the circuit could also introduce a lot of noise. That said, it would probably work fine.
Why do you want to use the wheel speed sensors? Too much extra mileage from spinning your tires?
Post by: rx7lee on February 24, 2015, 10:11:15 AM
Thanks guys. I want to use the abs sensor cuz I don't run abs and my transmission don't have a speed sensor
Post by: mdickw on February 24, 2015, 10:31:32 AM
Cool, let us know if it works..
Post by: Jordan Innovations on February 24, 2015, 02:12:30 PM
Generally the wheelspeed sensors aren't great places to pull speed from - the output is very low voltage, very fast, has to travel a hellishly long distance in the car, usually along with high-amp wires (battery, fuel pump, etc), and needs some filtering to be accurate or consistent.  The Dakota Digital boxes should have settings to bring the speed down enough, but I don't know if the output will be what you're used to seeing on a speedo.
My recommendation would be a mag sensor that reads the driveshaft nuts where they enter the diff - high-res, better speed (~16 pulses per wheel rev, vs 40), and less noise.
Post by: rx7lee on February 24, 2015, 03:24:05 PM
I was trying to keep from having to do that as it would have me trying to fab some kind of a bracket to hold the sensor but I think that is the best way to do it . I was hoping if I used a shielded wire from the and sensor to the box and used the sensor ground on the box that it would help with noise
Post by: stbrn19 on March 16, 2015, 02:52:18 AM
Any progress with this project?
