March 15, 2025, 10:48:02 AM
Author Topic: FC & FD Oil Pressure and Temp Sender Kits NEW!!  (Read 19461 times)
Offline shakenbake
« on: December 09, 2011, 07:20:51 PM »
So I always find myself hunting down all the parts it takes to make my Water Temp and Oil Pressure gauges work and it can be a pain and confusing if you are new at this swap. Here is a kit that will fir the FD or FC LSx swap and get your gauges working properly. You can get the oil pressure it in 10" and 14" hose lengths and can specify if you want a Straight,  45 or 90 degree fitting coming out of the top of the valley cover. The water temp sender adapter is drilled out and ready for the sender to drop in. Spade connectors and a grounding lug for the Oil Pressure sender is included. These are available with or without the actual sending units. A bunch of people buy the cars as rollers and don't have the senders from the rotary to get things working. All parts are brand new. If you've ever priced a Oil Pressure sending unit from Malloy you will find they are $80 just by themselves. I have kits in stock and ready to ship!!
Complete kit WITHOUT the Mazda sending units are $75 priority shipped.
Complete kits WITH both Mazda sending units are $150 priority shipped.
Paypal is hometheaterplus@mac.com
Re: FC & FD Oil Pressure and Temp Sender Kits NEW!!
« Reply #1 on: December 09, 2011, 07:44:33 PM »
That's a great price and a very handy bit of kit.
Offline shakenbake
« Reply #2 on: December 09, 2011, 07:49:30 PM »
Thanks Blake. I'm getting ready to put out a Flex-Braid wiring harness dress up kit as well. I may need you to just setup a vendor tab for me.
« Reply #3 on: December 09, 2011, 07:49:55 PM »
No problem, just shoot me a PM.  :)
Offline jparker7
« Reply #4 on: December 09, 2011, 09:00:36 PM »
post some pics of them installed
Offline shakenbake
« Reply #5 on: December 09, 2011, 11:14:40 PM »
Offline RX7what
« Reply #6 on: December 09, 2011, 11:53:12 PM »
How much are they seperate?
I am only looking for the oil pressure with out the sender.
PER AUDACIA AD ASTRA
« Reply #7 on: December 15, 2011, 05:07:33 PM »
Ordered a kit :)
Offline ltsr
« Reply #8 on: December 15, 2011, 08:48:14 PM »
Wish this stuff was around when I was putting my car together. Keep the good stuff comin!  :bacon:
///M
Offline shakenbake
« Reply #9 on: January 19, 2012, 06:06:41 PM »
Bump it up. I have a few more of these ready to ship out.
Offline Plex
« Reply #10 on: February 02, 2012, 02:34:51 AM »
Still have a few to ship out? I'll need both with sensors :)
Also, a pic of the water temp sensor mounting? I'm not sure where I'll put these... (as far as positioning the hose somewhere and strapping down the sending unit)
The Air Force gives out ribbons and medals like candy to keep us motivated.
Offline Adam P
« Reply #11 on: February 02, 2012, 03:31:18 AM »
Im a broke hoe right now ..I want a full kit how often do you have these on hand and can you quickly come up with one?
Offline shakenbake
« Reply #12 on: February 05, 2012, 03:10:26 PM »
I try and keep them in stock. I think I have 5 or 6 kits right now.
« Reply #13 on: February 05, 2012, 04:17:49 PM »
Don't think I posted here, but its good stuff.  Happy with my kit!
Shake, fyi the stuff you provided works well if you drill and tap the the oil cooler block off plate.  Corvettes get the oil temperature from this location I believe.  I still wanted oil pressure going to the ECM so I moved your sender down here.
Offline shakenbake
« Reply #14 on: February 05, 2012, 04:19:35 PM »
You can do that but some have had trouble with heat problems from the headers so I don't usually give people that option.
