March 17, 2025, 04:01:43 AM
Author Topic: Bikedad Go Boom!  (Read 23014 times)
Offline bikedad
Bikedad Go Boom!
« on: May 11, 2011, 12:16:59 AM »
Went to Great Lakes Dragway for Street Tire Tuesday.
First run: 60ft= 2.177
               1/4mi = 13.20 @ 111.31mph
2nd run: 60ft= 2.124
              1/4mi= 13.07 @ 111.69mph
3rd run: 60ft= 2.068
              1/4mi= 13.06 @ 111.01mph
4th run: Motor go BOOM! :o
I had a fantastic launch and the car was pulling hard. Just before the traps I think I over revved the engine trying to break into the 12 second realm. I heard this sickening pop sound and then the car shuddered. I cruised into the shut down area and noticed the car had a miss and there was a bad tink- tink- tink sound.
I instantly pulled it over on the return road and shut it off.
I didn't vent the block but there was a loud enough clanking sound to know something definitely was broken.
I think I either dropped a valve or broke a connecting rod. I'll find out when I get the motor pulled apart.
Bummer! It's the beginning of summer and my toy is broken. :(
I was contemplating going stroker. I guess I might be doing that sooner than I thought.
Don Teifke  :drive:
[smg id=8489]
-----John Wayne-----
Offline blacksi
Re: Bikedad Go Boom!
« Reply #1 on: May 11, 2011, 12:31:49 AM »
Could be something as simple as a rocker came loose.  On a positive vibe.
Offline bikedad
« Reply #2 on: May 11, 2011, 12:37:24 AM »
I hope it's something simple but I'm not taking bets. I should be so lucky. :P
Don Teifke  :drive:
[smg id=8489]
Offline Dr1ft1ng0wns
« Reply #3 on: May 11, 2011, 12:51:08 AM »
That sucks. Sorry to hear that Don, hopefully it's something cheap.
83 K5 Blazer on 37's
01 Civic DD
Offline bikedad
« Reply #4 on: May 11, 2011, 12:55:20 AM »
Me to.
Don Teifke  :drive:
[smg id=8489]
Offline Jordan Innovations
    • Jordan Innovations
« Reply #5 on: May 11, 2011, 03:36:11 AM »
I remember Great Lakes Dragway!!  Great track.
Sucks, but as was mentioned, might just be a stripped rocker bolt or something up top.  Did you check oil pressure when you heard the pop?  That's always what I do.
« Reply #6 on: May 11, 2011, 03:39:40 AM »
Oh snap! :o
Offline Rayminator
« Reply #7 on: May 11, 2011, 06:36:59 AM »
So close to a 12 sec. pass.
How did you get the car home? They do not let you leave them overnight at the track.
I will ask a friend what he has in his engine inventory, just in case it was a major event.
Offline BeatTheTunaUp
« Reply #8 on: May 11, 2011, 07:47:11 AM »
Sucks, I know the feeling.   I left it in 4th too long and spun a rod bearing with 800 miles on the motor :(        Not bad times for those 60ft times.   Easy 12's with some drag tires.  Every tenth of a second in the 60ft equals 2 tenths in the quarter.  Looking at 12.50's with an easy 1.8 60ft.    Oh well, on the bright side, the new motor is faster  :D
93 FD money pit
15 Ram 1500 Sport 4x4
98 Baja 192 Islander  5.7 vortec On the water
Offline bikedad
« Reply #9 on: May 11, 2011, 09:46:34 AM »
Don Teifke  :drive:
[smg id=8489]
« Reply #10 on: May 11, 2011, 11:14:04 AM »
Pics!  get that thing tore down!
Offline mattster03
« Reply #11 on: May 11, 2011, 11:15:12 AM »
ouch! what rpm did the failure happen at?
Offline bikedad
« Reply #12 on: May 11, 2011, 11:50:52 AM »
I got a good launch on the last run my 60ft was down to 1.9
I was in my torque curve early in the run and was at 6500rpm before the trap. I should have shifted but thought I could push it a little more. I think it let go at 6700rpm.
I'm running solid lifters. The valves don't float. Something just gives. :(
When I heard the pop I slammed it into neutral and coasted to the return road.
Don Teifke  :drive:
[smg id=8489]
Offline bikedad
« Reply #13 on: May 11, 2011, 01:21:35 PM »
So, minor update.
Got home for lunch and had to pull the valve covers to start the investigation.
#6 exhaust valve adjuster was sitting in the bottom of the head. Looks like the stud snapped.
I haven't turned it over yet to determine if anything else is broken.
Don Teifke  :drive:
[smg id=8489]
Offline theantirotor
« Reply #14 on: May 11, 2011, 01:24:17 PM »
so the stud snapped, but all of the valves were still in position?  may be a good idea to do a leak down before tearing it apart.  who knows, everything else may be ok!
:bacon:
