March 13, 2025, 04:01:45 AM
Author Topic: 98 Viper GTS Twin Turbo - Trade+$  (Read 3699 times)
Offline WAT TURBO?
« on: September 21, 2016, 06:17:00 PM »
1998 Dodge Viper GTS - Twin Turbo
67,500 Miles
Clean Title
$55000
Engine
502ci v10 ~1000 miles
Shortblock assembled by Rodney Butler - Butler Performance
CP Pistons, Oliver rods w/ new rod bolts
Billet Main Caps
ARP Headstuds and Main Studs
ATI Super Damper w/ ARP Bolt
Comp Cams custom camshaft and valvesprings
Comp Cams 3/8" Pushrods
Stopper style o-ring head gaskets
Aluminum foam engine gaskets (Viper Specialty Performance)
Greg Good ported cylinder Heads
T&D roller rockers 1.7 ratio
10 quart oil pan with trap door baffles
Upgraded oil pump with gen3 rotors
Setrab 72 row oil cooler with nylon braided lines
RSI Triple Pump Fuel Hanger - Dual Walbro 400 pumps. Could add a third pump for e85.
RSI Billet Fuel Rails
1000cc Injector Dynamics Injectors
AEM Infinity 10 Engine Management System
AEM Boost Controller
Moroso Catch Can
AB Black Spark Plug Wires
System 1 Billet Aluminum oil filter with Stainless Mesh Element
Dual Spal 1600cfm cooling fans in custom shroud (controlled by the AEM)
Re-Cored stock radiator with 4x 3/4" rows
HPS Silicone radiator hoses
3" exhaust through stock resonators to X pipe
Car put down 986whp 1030wtq at 13psi on 93 Octane Pump Gas.
Turbo System
RSI Twin Turbo system w/ black powder coating
Precision 6766 Journal Bearing, Billet Wheel, Vband in/out, 0.82 A/R
RSI Front Mount Intercooler, Bell Core
Tial Q Blow Off Valves
Tial MV-R Wastegates
RSI Oil line kit with fittings and scavenge pump
K&N Filters
Driveline
Spec Stage 5 Clutch ~1200 miles
New Clutch master and slave ~1200 miles
Unitrax 800hp Half Shafts
Driveshaft and Half Shaft Safety Loops
Lowering Caps
EBC Red pads and slotted rotors
Michilin Pilot Sport 2 front tires
MIckey Thompson street radial rear tires
Car will come with matching rear Pilot Sport 2 tires with good tread.
Interior
Electric Autometer Boost Gauge with alarm
Rockford Fosgate Power Series Components and matching 4 channel amplifier with crossovers
Pioneer AVH-P6300BT Head Unit. (Bluetooth, HD ready, Pandora, Iphone, DVD, SD)
Exterior
Clear Side markers. I have the stock ambers to go with it
1 significant rock chip on the hood, front drivers side.
Front fascia and sideskirts are in near perfect condition
MISC
New High Pressure Power Steering hose
Billet PS pulley
New Interstate Battery
Dodge Service Manuals 1998
AC system is charged and functional, but the AC on signal output needs to be set in the AEM. RSI can do this remotely or over the phone. I have not had time to sit down and do it. The output got reset after an update in firmware.
Here is a short cold start and walk around video.
I would consider a partial trade for a swapped FD and some cash.
Thank you for your time.
I have many more high res pictures I can email to interested parties.
Contact: wicksmotorworks@gmail.com
« Last Edit: September 23, 2016, 04:02:48 PM by WAT TURBO? »
-Chandler
1998 Viper GTS RSI TT
1997 Dodge Ram RCSB 24v Cummins swap
1990 300zx 2jzgte/r154, 264s, 67mm single
1988 RX-7 347ci, powerglide, 67/65 billet wheel.
Offline FC3S Murray
Re: 98 Viper GTS Twin Turbo - Trade+$
« Reply #1 on: September 21, 2016, 07:05:37 PM »
Wow, beautiful Viper. My favorite body style by far. I was in love with this car in my pre-teen days(still am today regardless of the OEM interior  :D).
If I had an extra 50k laying around I would jump on this without hesitation......dang, so envious.
I hope you find an  FD of your liking.
« Last Edit: September 21, 2016, 07:12:49 PM by FC3S Murray »
SRM Performance Tuning LLC
« Reply #2 on: September 22, 2016, 08:48:45 AM »
Offline WAT TURBO?
« Reply #3 on: September 22, 2016, 10:17:22 AM »
Thanks for the kind words.
@BeasTT
This thing is pond water compared to top fuel stuff  :cheers:
-Chandler
« Reply #4 on: September 22, 2016, 07:48:03 PM »
Nice!  :)
Where are you located?
Offline WAT TURBO?
« Reply #5 on: September 23, 2016, 04:03:16 PM »
Nice!  :)
Huntsville, AL. I added location to original post as well. Thanks!
-Chandler
Offline Tictakman
« Reply #6 on: September 23, 2016, 05:56:07 PM »
Any interest in a protouring black 68 camaro, ls1/4l60e?  Swap done by DSE.
