So we've been pretty busy
We wanted to take it to Import vs Domestic at MIR which is about a 1.5hr drive.
Problem #1: headlights don't work.
I found a burned up relay in the front I thought was the culprit but it turned out to be the fan. So we went searching for it and found the headlight relay.
Opened it up and...
We couldn't find any factory style relays so we got a kit and wired in one of the Bosch style 4 pin relays. Scott didn't like the hood prop rod so he built some struts for it and threw on the strut tower bar I gave him a while ago.
He had an extra diff from the last car that already had new bushings installed so he filled it with fresh fluid and slapped it in then gave it an alignment and balanced the wheels. The car was running amazing so we took it down to MIR. Car drove wonderfully.
Next issue to iron out is the starter. For some reason it really doesn't like to work once the car is warmed up. Any ideas?
