March 13, 2025, 04:01:34 AM
Author Topic: Sold...93FD turbo LS1 8.8 $15k driver $8k roller Peoria, IL ...SOLD...  (Read 14920 times)
Offline bdubs
Love this car, but after 7 years it's time for a new toy.
 93 RX7 base black cloth  interior 12x,xxx miles
A few small dents and scratches. Original paint is starting to fade.
2002 LS1 short block
317 heads patriot dual springs
LS6 cam and intake
TC76/68 turbo
80lb injectors 2x 255walbros
eboost 2
AEM wide band
RPM built t56 Textraila clutch
Cobra 8.8 DSS axles and driveshaft
Tien Flex coilovers
 build thread http://www.norotors.com/index.php?topic=18047.0
$15,000 as is or $8,000 as a roller with 8.8 diff and Hinson mounts.
Call or text for more details. 309-453-0998
Walk around video of the car
! Private video
« Last Edit: November 21, 2013, 07:26:10 PM by bdubs »
Offline Tictakman
Re: 93FD turbo LS1 8.8 $15k driver $8k roller Peoria, IL
« Reply #1 on: November 11, 2013, 07:39:14 PM »
Sounds like a possible good buy...
How is the interior?
Do you have any problem with cooling or keeping it cool?
What wastegate, and bov?
lbs of boost and dyno numbers?
Offline bdubs
« Reply #2 on: November 11, 2013, 08:33:59 PM »
I think it's a great price. Let's hope someone else does too and buys it. I would like to move it quick to make room for the next project.  I have 20k in it.
It's never had a cooling problem. It has a 160 thermostat,but stays right around 176*.
Tial MV44 wg and Tial 50mm bov.
14lbs. and 18* timing. I haven't had it on the dyno, just tuned on the street. But if you search you can find several combos exactly the same as this to give you an idea. It's probably close to 600/600.
Offline Demon
« Reply #3 on: November 11, 2013, 08:53:58 PM »
What headlights are those?
Car looks great! GLWS!
Offline bdubs
« Reply #4 on: November 11, 2013, 10:20:22 PM »
Thank you.
I can't remember who makes the headlights. I bought them about 5 years ago. The quality on them are not the greatest, but the look pretty good with the carbon fiber hood and all the other factory black trim.
Offline xbladr
« Reply #5 on: November 12, 2013, 11:41:39 AM »
Looks great man more pics? I see nothing of the interioir or just fully completed pics all around the car including engine bay body etc.
Offline CharmCity7
« Reply #6 on: November 12, 2013, 12:54:24 PM »
The headlights look like rotary extreme lights, but I could be wrong.  Seems like a great car for the price.  GLWS.
-Austin
Offline coltboostin
« Reply #7 on: November 12, 2013, 02:34:31 PM »
Interested in any trades+cash?
93 THE COLT 708whp 10.5@150mph Wreked@195
94 Colt "v2" 10.8@140-Sold
87 RX7, first ever 4G63's RX-7 11.5@125mph-Sold
06 Busa-9.6@151-Sold
05 CTS-V "Beater V"
90 RX7 first ever TT LSx FC.  Dyno Queen
BUILT NOT BOUGHT.
Offline bdubs
« Reply #8 on: November 12, 2013, 03:09:34 PM »
I doubt it. What do you have in mind?
Offline bdubs
« Reply #9 on: November 12, 2013, 03:11:08 PM »
I took a video showing some more details of the car with interior and will post it when it finally uploads. It's going very slow.
Offline coltboostin
« Reply #10 on: November 12, 2013, 07:10:03 PM »
CTS with Velocity.  ;)
PM'd
05 CTS-V "Beater V"
BUILT NOT BOUGHT.
Offline bdubs
« Reply #11 on: November 12, 2013, 10:59:29 PM »
Video added to original post showing some more details of the car.
Offline mx raptor
« Reply #12 on: November 13, 2013, 12:39:35 AM »
Tried to view the video link and it comes up that the video is set to private.
Also while I'm here I have a couple questions.
In the OP you said its a LS1 short block, but in the build thread it states the block is from a 02 C5 if I'm not mistaken which would be an LS6. No big deal since the blocks are nearly identical aside from some oiling ports.
What kind of rotating assembly did you put in? Pistons, rods, crank, etc.?
Is the car just set up to run E85 or is there a dual map switch from pump gas to E85?
How many miles are on the clutch? Track/street launches?
Not really a question but I did find a youtube video of your car on a dyno, but no #'s where given, the title of the video was bdubs turbo ls1 rx7 I believe.
I am somewhat local, (Chicago) and seeing the vehicle is listed as a '93 no emission testing is required correct?
Lastly, any A/C, heater, power steering?
« Last Edit: November 13, 2013, 12:46:13 AM by mx raptor »
Offline bdubs
« Reply #13 on: November 13, 2013, 09:15:32 AM »
video fixed. Sorry about that.
Offline bdubs
« Reply #14 on: November 13, 2013, 09:16:18 AM »
Z06's came with the LS6 block. Regular C5's came with LS1's
It's stock
No fancy map changing unless you have hptuners. I can load a 93 or e85 tune in it.
about 5k miles and maybe 5 passes at the track
That was a local dyno day last spring. I had just got the car running and it was not tuned yet. I put it on the dyno just to participate. 7.5psi, 6* of timing, and below 10afr it made 390whp. Now it has 14psi, 18*, and 11.3 AFR. It's the running joke locally that you just got beat by a 390whp car. lol
You would have to check your local regulations on emissions
No A/C, the heater works good, it has a KRC power steering pump
« Last Edit: November 13, 2013, 09:33:19 AM by bdubs »
