March 18, 2025, 05:43:36 AM
Author Topic: Fikse 3 Piece wheel rebuild and paint DIY.  (Read 5099 times)
Offline HXMan
« on: June 29, 2013, 11:30:58 AM »
So I've had a set of Fikse FM10's on my RX7 for some time.  The wheels previous owner didn't take the best care of the wheels and the inner barrels were pretty pitted, and the centers and lips showed signs of neglect.  So instead of selling the wheels as is and buying new ones I decided to rebuild them myself.
I didn't take many pictures of the breakdown, but here is one.  Once you remove all the bolts cut a slice with a razor blade all around the wheel through the silicone sealant, and then carefully pry the barrel and lip apart with a large screw driver.  In the picture you can see how nasty the inner barrels were.  The sealant on the floor was between the barrel and lip, I stripped most of it off with the razor blade.
Before pic of the centers.  They look to be in better condition in the picture here then they really were.
After broke them down I took the parts to a local sandblasting shop.  For $80 I got all the parts blasted....but they weren't ready for paint yet.  In this pic you can see the lip was pretty rough after the sand blast.  I sanded the lips down with 150 then 220, and then 350 grit.  I also did some sanding on the barrels.
Lip before sanding.
Lip after sanding.
It was a lot of sanding!  :'(  Ha, it really wasn't that bad.
I did some reading about painting 3 piece wheels, and how you really shouldn't have paint on the wheel mating surfaces.  I decided to have the wheels painted in stages.
First I had the lips and centers painted, with the mating surfaces of the parts masked off.  Needless to say I took a few trips to the paint shop.  You can't see in the pic, but the mating surface on the back of the centers is not painted.
Lips painted gloss black.
Nice parts chillin in my mud room. :)
I wanted the bolts nice clean so I let them soak in CLR, and scrubbed all 80 of them with a brush!  Came out nice.
Next I had to assemble the wheels.  Fikse wheel bolts need to be torqued to 14ft-lbs.  I didn't have a torque wrench that went that low accurately, so I bought a Snap-On 0-250 in-lbs torque wrench.
Torqued all the wheels in a star pattern, marking each bolt as I went to not miss any.
After the wheels are assembled, they all have to be sealed.  Don't apply sealant to the parts before assembly, you only do it afterwards. I went with GE supreme silicone.  It is good for aluminum parts, and worked great for me.  I also went with a clear sealant so I would be able to see any bubbles in the joint.
To apply the silicone first tape off around the joint.  The tape will make your sealant job come out much cleaner.
Then apply a thin bead around the entire wheel.  You don't need to much, but enough to completely cover the seam.  Run a wet finger over the sealant and smooth it around the whole joint.  Make sure there are NO bubbles in the sealant.
Before the sealant cures, remove the tape.  Now you will have a real nice seam.
Ready for final paint!
Not much more to say now.  I had the paint finished up.  Matte black on the centers, center caps, and barrels.
Guess a finished pic of the wheels on the car would be nice.  :cheers:
94 RX7 w/LS2 Swap
ASE Master Technician
Offline Spec C
Re: Fikse 3 Piece wheel rebuild and paint DIY.
« Reply #1 on: June 29, 2013, 12:51:29 PM »
They came out great.  Nice job.
My biggest gripe with black wheels is you can't see any of the detail.  On the pics of them mounted on the car I can barely even see the wheels. heh
Offline HXMan
« Reply #2 on: June 29, 2013, 12:56:04 PM »
Lol, thats my biggest problem with black wheels too, in pictures the detail isn't very visible.
Whenever I look at my car now though, I get this drooling sensation.  :D
94 RX7 w/LS2 Swap
Offline hayabusa
« Reply #3 on: June 29, 2013, 11:34:06 PM »
Very nice!
Offline tai-lun
« Reply #4 on: June 30, 2013, 01:24:51 PM »
Nice work and a great step by step!
I've been considering doing a rebuild on wheels and this will definitely help if I go that route.
Offline gc3
« Reply #5 on: June 30, 2013, 03:48:53 PM »
nicely done! for whatever reason i've never even thought about masking before gooping the sealant.
that makes so much sense and would have made everything look so much better if i had known before!
Offline HXMan
« Reply #6 on: July 03, 2013, 10:42:01 AM »
Thanks.  I hoped this would be helpful to people that are members of this forum that want to rebuild their wheels.
94 RX7 w/LS2 Swap
Offline TS motorsport
« Reply #7 on: July 03, 2013, 03:49:04 PM »
I rebuilt some CCW's for my Z06 and when I applied the sealant the way you did it to the first wheel it leaked. So I spoke to John and he advised me that the sealant was supposed to go on before the bolts are torqued down to 14 lbs.
04' Nighthawk Black Acura TSX 6spd/ 08' Prius 5/04' Maxima 5spd
Offline HXMan
« Reply #8 on: July 14, 2013, 05:54:23 PM »
I have heard of people doing it both ways.  Mine are totally leak free.
94 RX7 w/LS2 Swap
Offline karsty
« Reply #9 on: July 18, 2013, 02:29:08 PM »
Why didn't you get the barrels soda blasted or walnut shell blasted instead?  Something less abrasive to just take the old paint off and little metal.  Then you wouldnt have had to do so much sanding after the fact.
They turned out nice though.  Any close up pics?  Hard to see any detail.
