Plan is to keep it simple I picked up the chassis for 3k. Hoping to cycle junk yard LS motors through this chassis as they blow. I'll use arp head studs and GM MLS HG's. Keep Rpms low and boost high. E85 fuel. Only looking for 600-650 ftlbs. Won't be able to go much faster until I upgrade the cage.
This is the new chassis.
79 rx7 back half car rolling chassis.
Currie 9 inch with 35 spine moser axles and spool
competition engineering ladder bars and wheelie bars
8 point roll cage
Tires 29x12
Front factory struts with power disk brakes
2840 lbs Race Weight with 200lb driver
Powerglide Trans
Only have a few poor cell phone pics to start with.
Chassis...
Motor mounts done, test fit 5.3 with ls1 pan. Looks like theres room for a turbo or two in there...
Tried all 4 different LSX manifolds. This is the onlyone that would fit on the driver side. And it's pretty tight. Probably end up making my own here. Still looking for some LS3 manifolds to try.
